Traction problem - Mustang Evolution
Old 02-29-2004, 06:08 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
Traction problem
Well for a while now i have been talkin to Paul and he has been tellin me he has a hugh traction problem. now he has a set of 4.10s,3000 PI torque converter, all the bolt ons and a set of lowering springs. He says when he jumps on the gas his wheels just spin until he hits about 15 mph, Paul thinks it his lowering springs that are causing the wheel spin. Now how can this be fixed? I mainly ask this because I think im going to go the same route as Paul. thanks for the help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 02-29-2004, 07:17 PM   #2
Send a message via AIM to Blue232
well i really don't think it's his springs. could be alot of things. Such as tires (which is a reason alot of people can't get traction) could be to much power for his tires, most of the problems with traction are tires.
what kind of car does he have and what kind of tires?
Sold the sixxer
Got a 2000 5sp Black GT. I love it.
Blue232 is offline   Reply With Quote
Old 02-29-2004, 07:20 PM   #3
Send a message via AIM to NavyStang05
its probably the fact that he's got 4.10's and no weight in the back. Maybe some control arms would help, dunno. Does he have shocks to go with those springs?
NavyStang05 is offline   Reply With Quote
Old 02-29-2004, 07:47 PM   #4
Monkey's Avatar
i had all that, but i also had lower control arms. tell him to get some of those and he will hook better. but the springs dont really effect it. i would say it is tires or a lack of t-lok. (you never mentioned if i had one)
anyway, short answer: lower control arms and new tires
Old 02-29-2004, 08:34 PM   #5
Send a message via AIM to greenflash00
Just to clear up this post a tad... Im the one that this post is about, i have tloc and pretty good tires. I think the springs arent helping but i realize that im getting no traction b/c of the gears/converter. If i floor it from a stop i just light em up. I said that the springs werent helping b/c i notced i got worse traction after then even before the converter. Brandons right tho, lcas would help me out.
http://www.mustangmods.com/data/990/sig_2_resize.jpg
Gt takeoff exhaust with Flowtech Warlock mufflers, Mac CAI, ASP UDP, Flex Phenolic Spacers, 17 by 9 Cobra R's, 275/40s all around, FMS C-Springs, Tokico shocks and struts, FMS T-loc, FMS 4.10 gears, fordchip, 3000 stall PI tq converter, B&M Supercooler, and some various appearance stuff.
greenflash00 is offline   Reply With Quote
Old 03-02-2004, 07:11 AM   #6
Send a message via AIM to v6stanger
Lowering Springs definetly aren't helping the problem but they are not the sole cause.
Two of my friends have eibach lowering springs o ntheir msutangs with 300+ hp and still hook on the street. Its all in how you set up your suspension, tire pressure.
A nice set of upper and lower control arms will help out alot and a rear sway bar to add a little weight.
v6stanger is offline   Reply With Quote
Old 03-02-2004, 07:20 AM   #7
Danger Dude's Avatar
When you add gears and Tloc with a PI converter it is hard to keep the wheels from spinning. I really dont think the C springs are really causing problems because they are a stiffer rating than the stock springs. really is is all about weight in the back. lower control arms might help some as well as a rear sway bar. But do a test. take 50 to 100lbs and put it in the trunk and see if that makes any difference.
Old 03-06-2004, 07:55 PM   #8
Send a message via AIM to 232SCstang
try traction bars, my friend had a 1989 IROC camaro and all his car did was spin, a set of traction bars helped a lot.
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
Old 03-07-2004, 09:16 PM   #9
I don't have an automatic, but my T/A 255/50/16 drag radials have helped a lot with my traction over the stock Goodyear Eagle 225/55/16 street tires. It helped drop my quarter by 0.4~0.5 with the improved traction.
Full Length Densecharger; ASP underpulley; GT take off duals; 3.73 gears; T-lok (broke); Shorty headers; subframe connectors. shift light ready when I am.
15.10 Best 1/4 92.19 Best 1/4 mph (Pre-headers and connectors)(Still working on it. Target <15.00 next run)
6OnFire is offline   Reply With Quote
Old 03-08-2004, 11:27 AM   #10
well he doesnt have drag springs so any kind of stiff spring won't be good for launching.
He needs some suspension mods to keep himself planted..but he doesnt race the car that much so I don't see him doing that just yet.
A panhard bar, LCA's, and slicks/DR's will let you stick on the launch.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 03-08-2004, 02:44 PM   #11
cinder clocks in the trunk. Poor man's traction....
Old 03-30-2004, 10:44 AM   #12
old thread, bout traction
most people think that 50 psi in the tires is ok, but its not..thats just the max..you should let some air out...rear wheels, with low profile tires, shouldn't have much air in them i use to run 18 psi...sometimes 24..depending on the time of year,[hot or cold]...also depends on how you drive...32 psi is standard..,..
vdog is offline   Reply With Quote
Old 03-30-2004, 11:34 AM   #13
tire's Avatar
Send a message via AIM to tire
you need a firm spring in the rear for launching, just enough to squat a tad but other than that be solid, which would require it being stiff. they would be much better used with matching 50/50 shocks and control arms of course.
i wish i had my rear c springs back in because my 6 banger springs are too soft. :-/
tire is offline   Reply With Quote
Old 03-30-2004, 03:54 PM   #14
Zim
You want to **** me?
Zim's Avatar
sorry... lol
I like toys
Old 04-02-2004, 10:22 PM   #15
Rick0636's Avatar
Odd front springs seem to be easy to find, its the rear ones that are hard to get for some reason, not sure why, I think its cause a lot of people put coil overs in the front and leave regular springs in the rear??
Old 04-02-2004, 10:39 PM   #16
slvr2000stang's Avatar
Well I guess this is one time the extra weight for the vert actually helps.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 04-03-2004, 12:10 AM   #17
tire's Avatar
it's poorman's traction, but yeah it could help on the short track. less weight is always better in the long run, but if you don't want to sink $ into suspension, weight does work!
Old 04-03-2004, 03:41 AM   #18
Ponycarman's Avatar
Pinion snubber
1996 Mustang
1965 Barracuda
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 04-03-2004, 08:48 AM   #19
Rick0636's Avatar
I have actually hear of people that welded scrap iron to the top of there rear axle housings, so don't laugh at the cinder block idea, lol! BTW, I notice I get really good traction with my IRS rear axle, that sucker is really heavy looking, I heard like 70# heavier, I would bet more than that!
Traction control? braumab General Mustang Discussion 30 12-21-2007 01:50 PM
traction locs all8280bcc 1996-2004 Mustang GT 1 12-20-2006 09:34 AM
Traction Control Q wrecked2001 Pre-2005 V6 Mustang 12 03-20-2006 05:57 PM
Is traction really improved ? Joel5.0 1979-1995 Mustang GT 10 10-04-2005 03:55 PM
Grabbing traction? MustangMatt Pre-2005 V6 Mustang 6 05-12-2005 05:25 PM
04:52 PM
