ported intake question - Mustang Evolution
Old 03-03-2004, 08:14 PM   #1
Zim
You want to **** me?
Zim's Avatar
i just bought a ported intake from suprman and im wondering if theres anything that i have to besides take my old one off and put the new one on. Is that all i have to do or do i need to replace anything else?
I like toys
Old 03-03-2004, 09:38 PM   #2
Monkey's Avatar
if the gaskets are bad, then put new ones on. other than that, just swap them out and bolt everything back up. double then triple check you have vacuum hoses on, cause most of the time, you forget one
Old 03-04-2004, 04:59 AM   #3
Danger Dude's Avatar
Yes like Brandon said check the vac hookups. You have a 95 if he has a 97-98 intake there will be more vacume line hookups you will need to cap. Other than that it is remove and replace. I went the other way My stage 3 is a 94-95 and had less hookups than my 98 had.
Old 03-04-2004, 07:40 AM   #4
Zim
Zim's Avatar
i believe the one i bought was for a 95 as well so im hoping i dont have any extra hookups... we'll see
I like toys
Old 03-04-2004, 07:43 AM   #5
you should be all right
Old 03-09-2004, 07:58 AM   #6
Send a message via AIM to v6stanger
Zim: IM me later tonite about that intake from Suprman.
v6stanger is offline   Reply With Quote
Old 03-09-2004, 11:45 AM   #7
RGR
Send a message via AIM to RGR
IMO you need at least a 1/2 shafted TB or a bigger TB to
take advantage of a ported intake. 1/2 shafted and ported,
a stocker will flow LOTS more than stock, so it is worth it.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-09-2004, 02:48 PM   #8
my next mod after a tune ^
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 03-09-2004, 04:05 PM   #9
Rick0636's Avatar
Better off to change tbodies before tuning if you are going to do a tune, changing after will only mess up your tune.
Old 03-09-2004, 04:53 PM   #10
the car would adapt enough for a small change like porting out a TB.
I have enough problems and the tune is necessary.
New Hottness
1999 V6 5-speed
Wrecked
Old 03-09-2004, 05:30 PM   #11
Rick0636's Avatar
ok then
Old 03-10-2004, 04:27 AM   #12
RGR
I agree with rick in most situations, but if $$ are low, then it would be OK.
Old 03-10-2004, 06:47 AM   #13
but if $$ are low
very
New Hottness
1999 V6 5-speed
Wrecked
Old 03-10-2004, 07:18 AM   #14
RGR
you might wanna check out my new Poly-Hone process...
I can finish off your intakes in grand style
Honed as a single unit 8) Since they are already
ported, it would be cheaper!
Old 03-14-2004, 06:02 PM   #15
Suprman's Avatar
Send a message via AIM to Suprman
yeah you should be allright, but i would check the gasket! if you need a vac cap, i think i have some lying around here that i could send you one, also i think i'll have my TB that was half-shafted and ported by RGR up for sale soon as i'm going with a 60mm GT TB!
i think if you had it polyhoned it would be awesome as well! i'm thinking of getting my stage 3 intakes done!
Click On Sig For More Info
http://www.mustangmods.com/data/6447/suprman.jpg
Best 1/4: 15.49@88MPH
Originally Posted by a232stang
SUPRMAN KICKS ***.
Suprman is offline   Reply With Quote
Old 03-14-2004, 08:30 PM   #16
Zim
Zim's Avatar
suprman, is this an intake from a 94-95 or am i going to need some vac caps?
I like toys
Old 03-14-2004, 10:24 PM   #17
Suprman's Avatar
honestly i can't remember! lol i think it might of been 95 but i'm not really sure!
SUPRMAN KICKS ***.
Ported Intake SC_STEEDA Pre-2005 V6 Mustang 2 08-15-2008 03:33 PM
Ported & Polished Lower Intake VCS_SSSTANG Pre-2005 V6 Mustang 0 08-03-2008 05:23 PM
Ported Intake Manifold..STRESS 99'sleeper Pre-2005 V6 Mustang 5 03-10-2005 08:10 AM
Powdercoated & Ported 99+ Upper Intake stangin99 Mustang Parts for Sale and Wanted 5 04-28-2004 10:29 AM
Ported Intake Dealers MusclesFromBrussels Pre-2005 V6 Mustang 38 11-01-2003 07:44 PM
07:10 PM
