Running Hot.... - Mustang Evolution
Old 03-05-2004, 11:09 AM   #1
Send a message via AIM to Shortie630 Send a message via Yahoo to Shortie630
Running Hot....
My car is running hot..its a 95 v6 ...stang..of course...i checked everything...all of the oils and waters and antifreeze stuff..and everthing is good...so i had my stepdad look at it and he said that the fan wasnt working...how much would a fan cost...? and if it will work sometimes...would i still need to get another one??
Shortie630 is offline   Reply With Quote
Old 03-05-2004, 11:24 AM   #2
Zim
You want to **** me?
Zim's Avatar
be careful... it could be signs that your headgasket is about history!! 95s had horrible head gaskets so id suggest not driving it until you know for sure what the problem is! Also 95s had a recall on the fan bearing or circuit breaker or somethin like that so that could be your problem too. whatever the problem is, dont drive it until you know whats going on with it because you could end up having to replace your whole engine
I like toys
Old 03-05-2004, 11:26 AM   #3
tire's Avatar
Send a message via AIM to tire
classic headgasket-itis. sorry bud. i hope you got knowledgeable friends to replace it. where's florence, i doubt it's the one in italy.
tire is offline   Reply With Quote
Old 03-05-2004, 11:27 AM   #4
Danger Dude's Avatar
Florence SC or Florence CA????? If it is SC we have boatloads of people to help!!!
Old 03-05-2004, 11:31 AM   #5
Region: New Hampshire
Send a message via AIM to Smokedya95stang
Sup man,
Welcome to the boards.
Just letting you know that there was a recall for 94-95 stangs for a # of stuff.
But all of which can be corrected.
Unfortunatly, you cant benifit from the recals anymore, but one was abuot the
cooling fan.
Read all your recalls here:
http://www.v6stangs.com/index.php?page=v6_stang_specs/recalls/95_recall.php
-Charles
Smokedya95stang is offline   Reply With Quote
Old 03-05-2004, 11:33 AM   #6
Oh PS: my fan blew, and i brought it to ford, they said they fixed it, they didnt, it didnt turn on, and i blew my radiator.
Ford bought me a new one, and i installed it. Then i just wired a fan switch, so i can control it.
Its probabyl not the fan thats broken, its probably the control module for it.
So i just didnt want to screw around with it, and wired a swtich to it. What you can do is get some wires going to the fna to the batter to just test the fan to see if it works.
Dont go to ford they suck.
-Charles
Old 03-05-2004, 01:04 PM   #7
Black95GT's Avatar
Send a message via AIM to Black95GT
How does it overheat, does the gauge stay Cold and then jumps uo to Hot, open up the radaitor cap, see if air is coming out, I had the same problem as you, mine was a headgasket. Sorry man, its sucks, I am getting it done for 300, and I bought new heads, but your looking at 1,500 to 1,900 from ford, they stopped paying for them a while ago.
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 03-05-2004, 01:22 PM   #8
cross ur fingers and hope its not headgaskets, i really dont think it is though.
How many miles are on the car?
Plus, if u checked oil nad antifreeze and u said it was fine, then i bet ur ok.
Just keep a close look for it.
-Charles
Old 03-05-2004, 01:23 PM   #9
Black95GT's Avatar
I checked my oil it was fine, but I blew a headgasket, best I can tell you is dont run it....ull get it worse if it is
-Jason
Old 03-06-2004, 08:14 AM   #10
RGR
Send a message via AIM to RGR
we need to know how it is acting up, it could only be the
fan if you are lucky but that can weaken the HG too! So
get it checked ASAP!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-09-2004, 10:52 AM   #11
i got it looked at the other day at school...he said that i need a cold air modulator...what ever that is..
..i dont know how many miles are on my car...it was wrecked a while back..head on and the mileage doesnt work...
..btw..im in florence, SC
Old 03-14-2004, 06:48 PM   #12
how hot are you running. is the needle going past the normal bracket? did you check if there is power going to the fan connector? i think the fan only comes on at 250 degrees. you should check for power going to the fan before you spend money on a fan.
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 03-25-2004, 10:19 PM   #13
Send a message via AIM to 232SCstang
Originally Posted by widowvirgin
:how hot are you running. is the needle going past the normal bracket? did you check if there is power going to the fan connector?
We need more information. Did you check your thermostat?
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
Running Hot Gray Ghost 1979-1995 Mustang GT 13 01-14-2011 12:02 AM
what should i be running? tigercrazy718 General Mustang Discussion 0 05-19-2010 02:31 PM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
Running the V-6 05STANG Pre-2005 V6 Mustang 5 02-13-2006 07:36 AM
06:55 AM
