freeze plug - Mustang Evolution
Old 09-23-2008, 08:55 PM   #1
freeze plug
I have gotten a new/used engine to replace the one I blew up. I've gotten it all torn apart and am cleaning it, and it appears that there is a freeze plug floating around in the blocks's coolant chambers.
Any suggestions as to how I might get it out? I think it's too big to just leave there. Looks like it might block coolant flow. I see freeze plug kits online, but punching holes in my heads is a bit scarey.
Thanks,
Sarah
shustwit is offline   Reply With Quote
Old 09-24-2008, 01:59 AM   #2
Re: freeze plug
do u have an engine stand? it may do u wonders so that u can flip the engine around to see if its willing to come close to the hole so u can take it out, if not a little magnet that extends from an autoparts store might do the trick. as far as removing the rest of them, i usually take a screwdriver and tap a hole kida close to the egde until it penetrates the freeze plug then pry it out. there are replacement freeze plugs available, but sometimes they are size specific so u might want to measure yours as best as u can. there are also the rubber/metal freeze plugs that compresses the rubber as u tighten them up as replacements and it installs easily.
p.s. welcome to the site:beer:
96 GT- Who knows what's in it.
Old 09-24-2008, 06:14 AM   #3
Re: freeze plug
chances are if the freeze plug is in there, its not just going to fall out, you wil have to find a way to get it where you can drill a 1/8" hole in it, and screw a screw in the side that would be the inside if it was installed correctly, then use a slide hammer to pull it out just as if you were installing one into the motor but slide hammer it until it comes all the way through
SimplyOrange is offline   Reply With Quote
freeze plug leaking coolmustanguy Pre-2005 V6 Mustang 5 08-14-2010 09:06 AM
New Plug Wires Foxone Pre-2005 V6 Mustang 1 11-06-2009 06:19 PM
Spark Plug 1234 The Bar 9 08-07-2008 09:23 PM
Plug wires Ghostbuster Pre-2005 V6 Mustang 0 04-10-2005 06:57 AM
Which damn plug? Feo Pre-2005 V6 Mustang 18 12-07-2004 12:18 PM
05:12 PM
