*UPDATED W/PICS* Need help ASAP! - Mustang Evolution
Old 03-10-2004, 08:39 AM   #1
01mineralgrey6's Avatar
Im in the middle of installing headers...I can't get the dipstick tube out of the drivers side. I unbolted it and pulled on it but i can't pull it all the way out cuz the top of the tube is hitting the brake booster, and the valve cover.Do i have to bend the tube a little?? any help is appreciated.
-Tony
'99 cobra 'vert
Old 03-10-2004, 08:56 AM   #2
Danger Dude's Avatar
Yes you do have to bend the tube a little but be carefull and bend it near the top and not where it goes into the block or you will snap it off. BE CAREFULL VERY CAREFULL!!!
Old 03-10-2004, 09:01 AM   #3
Alright. Ill go do that. Thanks Corey!
-Tony
'99 cobra 'vert
Old 03-10-2004, 09:03 AM   #4
No problem
Old 03-10-2004, 09:07 AM   #5
Got it!!! Your the man Corey
-Tony
'99 cobra 'vert
Old 03-10-2004, 09:14 AM   #6
Sweet
Old 03-10-2004, 10:37 AM   #7
Any tips on the passenger side of the engine... not alot of room. I wish I had air here
-Tony
'99 cobra 'vert
Old 03-10-2004, 11:48 AM   #8
I dropped the Y-pipe, and have almost all the bolts loose on the pass. side manifold....I don't have a wrench big (biggest is a 7/8s)enough to fit the EGR tube, I think its about 1" or slightly bigger not sure I would just use some channel locks but theres not enough room to get some up in there. So right now im stuck
-Tony
'99 cobra 'vert
Old 03-10-2004, 12:37 PM   #9
anyone
-Tony
'99 cobra 'vert
Old 03-10-2004, 12:58 PM   #10
tire's Avatar
Send a message via AIM to tire
open ratcheting wrenches and swivel sockets are a must. well, if you want to get it done anytime soon. take pictures if you can of what your problem is exactly and we can help better. what do you have, shorties or longtubes?
tire is offline   Reply With Quote
Old 03-10-2004, 01:44 PM   #11
They're shorties.I need to take off the EGR tube.
and the furthest rear manifold bolt is giving me alot of trouble.
-Tony
'99 cobra 'vert
Old 03-10-2004, 01:55 PM   #12
Can you go from the bottom of the car !!!!
Old 03-10-2004, 01:57 PM   #13
Ill give it a shot.
-Tony
'99 cobra 'vert
Old 03-10-2004, 02:08 PM   #14
tire's Avatar
what do you mean "manifold bolt", there is only primary tubes (the small ones that contact the heads) and the collector, which is the large flange on the bottom side.
Old 03-10-2004, 02:16 PM   #15
Thats what I ment is the primarys at the bottom rear. It won't budge, I can't even pull the stud out of the head....I think im just going to take it somewhere and have them finish it up
-Tony
'99 cobra 'vert
Old 03-10-2004, 02:24 PM   #16
did you spray it with WD 40 or any type of penetrating oil to loosen it up???
Old 03-10-2004, 02:45 PM   #17
I did. well now that i got the y pipe dropped down I might be able to get a better shot at it. Ill spray it again and let it soak in for a little while.
-Tony
'99 cobra 'vert
Old 03-10-2004, 04:18 PM   #18
tire's Avatar
wd40 is alright, but get the little straw that you can put on the can and put it on LIQUID WRENCH. LW helps a lot more than wd40. get a 6 point ratcheting (sp?) wrench as well if you can't get at it good.
Old 03-10-2004, 07:44 PM   #19
I got it finally..I went out and bought some liquid wrench sprayed that on there, and let it sit for a little bit, and was able to break it loose. Sounds about the same as it did before. slightly deeper. and it seems to pull a little harder. I would love to get it on a dyno but I have no clue what the gains are..Thank you guys for your help. :thumb2:
-Tony
'99 cobra 'vert
Old 03-10-2004, 07:44 PM   #20
oh and Ill get some pics on here tomorrow
-Tony
'99 cobra 'vert
Old 03-10-2004, 08:07 PM   #21
tire's Avatar
good job, congrats, header installs on a car without pulling the motor is one of the more frustrating mods.
Old 03-11-2004, 01:34 PM   #22
heres the pass side. not alot of room
Drivers side
With header
Drivers side. taken today already starting to blue
Little comparison
That damn egr tube
[/img]
-Tony
'99 cobra 'vert
Old 03-11-2004, 01:38 PM   #23
Got a little more noticeable power at mid rpm range. Sounds much more agressive when under a load. I don't think I would want to do another set and you guys with long tubes I feel for ya.
-Tony
'99 cobra 'vert
Old 03-11-2004, 01:45 PM   #24
nice dude. Big difference in look
Old 03-11-2004, 01:50 PM   #25
Yeah, they look better . I probably wouldn't have bothered with them if it wasn't for the pass side one being cracked Oh well, It got rid of that god awful exhaust leak so it no longer sounds like a farm truck with no exhaust.
-Tony
'99 cobra 'vert
Old 03-12-2004, 08:23 PM   #26
RGR
Send a message via AIM to RGR
01mineralgrey6,
hey, what R U doing with the stock headers?
I know 1 is cracked, so they are not worth
much if anything, but can get it welded and
I need a set of any kind of V6 headers.
LMK!
I'll pay shipping
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-14-2004, 06:41 PM   #27
i think you should be using metric...god it sucks to round off bolts and nuts!
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 03-15-2004, 07:19 AM   #28
RGR, you have a PM
-Tony
'99 cobra 'vert
Old 03-15-2004, 08:41 AM   #29
RGR
RGR, you have a PM
Kewl, I will probably use those "headers"
as my method to Poly-Hone exhaust ports
47807 is my ZIP, for figuring shipping!
Thanx Tony!
Who watches overhaulin? *UPDATED NEW PICS* PureVenom The Bar 17 07-17-2005 10:38 AM
Updated Pics of my Install Kiljosh Pictures and Videos 0 07-02-2005 04:04 PM
updated car pics Bane- Pictures and Videos 13 03-29-2005 06:08 AM
New Shelby...HI RES Pics...Updated With Pics PureVenom The Bar 15 03-25-2005 09:53 AM
updated pics of the killa' V6 timpryor Pictures and Videos 14 03-19-2005 02:49 PM
01:59 PM
