re adjust clutch? - Mustang Evolution
Old 03-10-2004, 04:22 PM   #1
Send a message via AIM to blk2kconvstang
re adjust clutch?
How do i re adjust my clutch or can I not adjust it? the clutch has to be a little more then 3/4 out for it to engage. but when i pop the clutch it grabs hard and doesnt slip so i think the clutch should be fine.
blk2kconvstang is offline   Reply With Quote
Old 03-10-2004, 07:31 PM   #2
oh, and would that be covered under the warrenty? it's a 2000 but i have a 2 year warrenty
Old 03-10-2004, 07:45 PM   #3
01mineralgrey6's Avatar
just lift up on the pedal with your foot, that will adjust it
-Tony
'99 cobra 'vert
Old 03-10-2004, 08:44 PM   #4
well, how many times or how hard, i tryed that and it didnt seem to make a differance
Old 03-10-2004, 10:56 PM   #5
Send a message via AIM to Black00GT
your need a Clutch Adjuster Kit in order to make it to where you don't have to release the clutch so far. here is one. you can get them from alot of different places.
http://www.steeda.com/store/-catalog/ClutchAdjusterKits.htm
2003 Silverado Z71
Mods:
K&N filter, Black diamond plate toolbox, and billet grille on the way.
Future mods:
6" lift kit, rims and tires, Catback, Rhino lining, System
Black00GT is offline   Reply With Quote
Old 03-10-2004, 10:57 PM   #6
If you get one of those you can change it to how you like it.
2003 Silverado Z71
Mods:
Future mods:
Old 03-11-2004, 10:17 AM   #7
you lift up on the petal and push it down which will probably do nothing. You can get under there and push the petal down and ease out while you hold the pawl back off of the gear on the quadrent and make it take up slack but that usually dotn last long... if you ever touch the under side of the petal the adjustmetn is gone. I would buy an aftermarket quadretn and adjuster with the MM petal height adjustment.
Old 03-14-2004, 06:16 PM   #8
if you're worried about your clutch then it should be fine according to how you described it but if you want to lower your clutch pedal then you need a quad. and adj. cable. gtrhipo.com has a good price but they are cheaper somewhere else i just can't remember. my clutch was making a squeeking sound so i installed the new quadrant and adjustable cable and the sound went away! i also adj. my clutch pedal to be more even with the brake pedal.
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 03-16-2004, 05:29 PM   #9
just putting in a quadrent and cable will not lower the petal (well it can but you will not have any tention on the cable as you should) also get a Maximum motorsports petal height adjuster so that you can lower it and keep it adjusted right, you only want a half inch play before the cltuch starts to grab. just go down the road in 5th with cruise control on push the clutch in if you have .5 inches before the rpms start to come up your fine
Old 03-18-2004, 05:10 PM   #10
you don't need the mm pedal height adjuster...all you need is a bolt and 2 nuts.
Old 03-18-2004, 06:13 PM   #11
Old 03-20-2004, 04:29 PM   #12
there is a sort of mounting plate to the right of the clutch pedal with a few holes in it. i pushed my pedal down installed and 13mm head bolt with a 13mm od nut on it and a nut on the outside...then i let the pedal up and adj the cable. if i wanted it lower i would just put a rubber sleeve over the bolt...and that's it. it works beautifull along with my home-made semi-short throw shifter!
Old 05-08-2004, 07:11 PM   #13
how did you make a short shifter????
Old 05-08-2004, 07:12 PM   #14
all those products are avalable at v6mustangstuff.com
Old 05-09-2004, 10:05 AM   #15
a simple cut and weld.
Old 05-11-2004, 07:02 PM   #16
buy a steeda tri ax, b&m ripper those are the only 2 i like or a pro 5.0 base with a steeda handle the pro 5.0 handle suckxors
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 11:19 AM
clutch help mtchll50 1979-1995 Mustang GT 9 09-10-2006 07:09 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
new clutch Johnny D Pre-2005 V6 Mustang 9 03-05-2004 07:47 AM
01:37 AM
