Bad luck with drivetrain.. - Mustang Evolution
Old 02-05-2004, 02:03 PM   #1
Last year I noticed my T-5 was leaking fluid out of the speedo-cable location. I tightened up the bolt and it stopped leaking. Didnt look like I lost much fluid so I continued running it around. About 2-3 weeks later the tranny went south. Lost 2-3-Overdrive. When I finally got it out and got it to the tranny shop the said it needed new bearings, brass, syncro's, input & output shafts, and the case was cracked. It was cheaper to by a new t-5 then it was to have that one gone through with a HD rebuild. Ended up going with a tremec and hopefully it lasts longer than 600 miles..
-Smoke
1990 Mustang GT-
347 Stroker-Tremec 3550-Compucar Nitrous, AFR, Systemax Intake, AFM, 30lbers, 70MM TB, 76mm MAF, full suspension and lots more
1995 Chevy S-10
406 SBC, Dual tunnel ram, Dart heads, Nitrous, full tub, 4-link, adjustable drag shocks, coil-overs, 9in rearend, 4.56 gears...etc
Click here to visit the my webpage
Smokedawg is offline   Reply With Quote
Old 02-05-2004, 06:27 PM   #2
Tbird232ci's Avatar
a Tremec should do you well, a friend of mine has a 351w in his 88 Cougar, build rather nicely, with a 3550 behind it, it holds up no problem at all
Old 02-08-2004, 08:21 PM   #3
Should of checked the fluid level huh? Lessons learned hard way.
Jayber is offline   Reply With Quote
Old 02-08-2004, 08:23 PM   #4
Region: Idaho
My brother has a TKO behind a 347 in his 1992 GT. It is a strong transmission, and will take a lot of abuse. Personally, I will be going with the G-Force T-5 rebuild. I like the feel of the T-5 over the TKO.
Doug
The Problem Is Not With Guns. It’s Hearts Without God, Homes Without Discipline, Schools Without Prayer, and Courts Without Justice.
427windsorman is offline   Reply With Quote
Old 02-09-2004, 05:55 AM   #5
Got the tremec in this Saturday..Man that tranny is a lot heavier than the t-5. The install went pretty smooth though...
1990 Mustang GT-
1995 Chevy S-10
Old 02-09-2004, 03:04 PM   #6
I thought the 3550 was like 110lbs and the T5 was like 90lbs? Just from memory
More bad luck Scut95 The Bar 7 07-15-2008 08:54 AM
Wow What Some Bad Luck bluemustang The Bar 4 02-01-2007 11:05 AM
Bad Luck Stikes AGAIN Mustang414 The Bar 20 05-29-2005 11:10 AM
Well guys looks like my bad luck continues..... Brent The Bar 17 12-19-2003 12:41 AM
03:08 AM
