Computer Tunning 99 up GT AOD - Mustang Evolution
Old 02-12-2004, 06:17 PM   #1
I Have a Questions that i need help in here. I have a 2000 Mustang GT
With a Automatic Tranny I have Xipe with No cats, Cold Air Kit, Underdrive Pullys, and 373 Gears, I just got the chip and gears i have Pro M new chip and i was wondering does anyone know, what is a good timing for my car and
some Good Shift Points for my car like at what speed and RPM chould it shift in cause i kno the chips help with the shifting please help me out !
fastball450 is offline   Reply With Quote
Old 02-12-2004, 07:30 PM   #2
Send a message via AIM to Junior2561
i would have it tuned. Get your A/F straightened out, get the gears calaberated, and have your shifts and timing done thourgh that. Best way to do it.
Junior2561 is offline   Reply With Quote
Old 02-12-2004, 09:35 PM   #3
Rick0636's Avatar
All of that stuff should have been programmed into your chip. If you have already gotten a chip, its a little late to worry about it, you are sort of stuck with what its programmed for now unless you do go for a dyno tune.
Old 02-17-2004, 10:24 PM   #4
Send a message via AIM to Black00GT
how much does a dyno tune cost normally?
2003 Silverado Z71
Mods:
K&N filter, Black diamond plate toolbox, and billet grille on the way.
Future mods:
6" lift kit, rims and tires, Catback, Rhino lining, System
Black00GT is offline   Reply With Quote
Old 02-17-2004, 11:24 PM   #5
Rick0636's Avatar
I am not sure really, never had it done. Corey (Danger Dude) on www.v6stangs.com has had a dyno tune done, he should be able to give you a good idea of the cost if no one here knows.
Old 06-18-2004, 02:58 AM   #6
For his combo, I don't really see the benefit of dynotuning it. I can get it dialed in...we have worked on enough of these. A dyntoune is worth around $500-600 including dynotime, and I honestly don't see it being wiorth it on his car.
Alberto@American MotorSport
www.americanmotorsport.com
Supercharged '00 4.2L Mustang, 5-sp
-Vortech (custom setup using 94-98 kit), 12.5psi, IMRC's, custom power pipe, 80mm Lightning MAF, 42# injectors, FMS 8.8 rear-end, 300lph returnless pump, polished '99 Cobra's, Tri-ax shifter, 160° thermostat, FMS Aluminum Driveshaft, high-flow H
313rwhp/311rwtq
americanmotorsport.com is offline   Reply With Quote
Old 06-25-2004, 10:48 AM   #7
SCT and Black Diablo chips, for example, are reprogrammable. That means if the dyno shop has the software for either one they can put your car on the dyno, collect data, and make adjustments to the chip to make it run better, safer, or to increase power depending on the situation.
I think there is some confusion about dynotuning. Just because a shop has a dyno doesn't mean they can tune an OBD2 96+ car, on a stock car there is nothing that can be manually changed. If you add a AFPR then fuel pressure (and thus delivery) can be slightly adjusted but its a blanket change that does not work well. On older 5.0s blanket timing adjustments can be made which is not the best way to tune.
However, with the proper tuning software hundreds of parameters can be adjusted and the vehicle can actually be truly "tuned".
Most lightly modified NA cars won't benefit from a dynotune, a good chip program will be fine.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 06-25-2004, 12:23 PM   #8
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
Yeah, you don't really need a tune until you get a power adder or a lot of bolt ons. It will get you a few hp in a stock car, but that's not really worth the money
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-25-2004, 12:30 PM   #9
Zim
You want to **** me?
Zim's Avatar
yeah this threads 4 months old and he hasnt replied since his original post...
I like toys
Old 07-03-2004, 10:09 PM   #10
Depends on the car..Some make great gains even stock, some don't. There are also other benefits.
313rwhp/311rwtq
Old 07-03-2004, 10:09 PM   #11
LOL
313rwhp/311rwtq
89 AOD question bob2231 1979-1995 Mustang GT 0 04-12-2008 09:12 PM
Great Info on: Tunning, power adders, etc SpectorV General Mustang Discussion 4 04-24-2006 08:14 AM
AOD Questions GizmosMustang 1979-1995 Mustang GT 5 02-09-2006 11:18 AM
aod on a 289 STEVE Pre-2005 V6 Mustang 8 05-11-2005 11:31 PM
Computer problem....for all you computer gurus.. Rick0636 The Bar 59 02-19-2005 11:42 PM
04:21 AM
