Mustang V6 Problem. - Mustang Evolution
Old 10-04-2008, 12:45 PM   #1
Exclamation Mustang V6 Problem.
I have a '99 Mustang V6
Ok so this is how the problem started. And pardon my non-technical terms for im new to this.
First my AC compresor fried.
- Had it replaced for a new one.
Now the car is "fine" when the AC is not on. But when I turn it on. Even though the AC is is blowing cold air. The car idles and RPMs drop below normal including a bit of shaking and a ticking sound just like old chevy trucks.
This causes the AC compresor to turn off and on as the RPM goes up and down. When I accelerate everything is just fine. The only thing is when im above 60mph I hear the ticking sound again as if there was a gasket loose in the pipe or something.
My car has a dual exhaust adaptation with Flowmasters but they removed the catalytics, so it has a straight pipe installation. Also the Check Engine light is always on. (im guessing because of the missing catalytics)
I don't know if this is a vacuum leak or a gasket being worn out. Any one that has come across this issue please help.
Thanks in advance.
nexuslair is offline   Reply With Quote
Old 10-04-2008, 03:29 PM   #2
Herbstang's Avatar
Re: Mustang V6 Problem.
Yeah no cats will throw a light .Clean your MAF and check for leaks Who did the A/C install ?? If a shop did it have them check for vacuum leak If you did it re check your install
Old 10-04-2008, 03:38 PM   #3
Herbstang's Avatar
check the ac belt tension. adjust the ac idle speed there's a idle adjustment when ac is on (rpm goes up).Check your freon level if it's low the idle will go up and down
Old 10-11-2008, 12:50 PM   #4
1RNKPNY's Avatar
Without the Cats in place, (A) the exhaust passes by the sensors so fast that they don't have time to properly get a true reading, and (B) with the OBDII system you will have pre and post O2 sensors. They will read the same thus probably throwing a TWC (3way cat) inefficiency or below threshold codes. The only way to turn the light off is to install high flow cats.
1RNKPNY is offline   Reply With Quote
Old 10-13-2008, 11:40 AM   #5
1234's Avatar
Or get MIL elimantors. Or a tuner and turn the back sensors off.
66 Mustang taillight wiring problem mustangmatt_66 Classic Mustangs 3 08-18-2009 05:01 PM
Air Conditioning problem - 96 Mustang V6 WVKarenC 1996-2004 Mustang GT 8 06-15-2009 12:42 AM
Need Help with Rear End Problem on my 70 Mustang blk66stang Classic Mustangs 3 12-03-2008 02:51 PM
06 mustang rearend problem chino mustang 2005-2010 Mustang GT 5 07-11-2007 09:12 PM
05 Mustang GT draw problem mustanggtgirl05 2005-2010 Mustang GT 5 09-24-2006 09:21 PM
01:56 PM
