ASP and Mac - Mustang Evolution
Old 03-21-2004, 06:06 PM   #1
McGrail482's Avatar
Region: West Virgina
Send a message via AIM to McGrail482
ASP and Mac
Ok i know what the underdrive pullies do but, mac and asp both have pullies and mac comes with two and asp comes with one, what is the difference in HP gains between the brands (if any) because one is more expensive (at EE). which one do you guys recommend? also dont both require new belts.
sorry about the ****ty explanation...
-Jason
2015 5.0 Mustang
Previously Owned:
1995 3.8 V6 Mustang-True Duals w/Mac Flowpaths, BBK CAI
2012 Ford F150 FX4
McGrail482 is offline   Reply With Quote
Old 03-21-2004, 06:25 PM   #2
More than likely one of them is for a 94-98 and one is for a 99+ the 99+ comes with one pulley and is more expensive while the 94-98 come with 2 and are cheaper.
Old 03-21-2004, 08:41 PM   #3
01mineralgrey6's Avatar
I know the 99+ needs a shorter belt. and also the 99+ comes with a new harmonic balancer(not sure about 94-98) and if you have a 99+ they changed the balancer about halfway in 2000 so theres 2 diff ones for the 99+
-Tony
'99 cobra 'vert
Old 03-22-2004, 07:35 AM   #4
Concordium's Avatar
http://www.velocitymustangperformanc...cts/pulley.htm
6th one from the top. thats the one im getting. has 25% crank pulley, 10% water pump pulley and 15% OD alternator pulley.
Silver '96 V6
Mods: True Dual Exhaust, Flowmaster 40's, Cobra Diamond Clear Headlights and Side Markers, Shortened Antennas, Blue Dome Light, Metallic Blue Painted Calipers, 4.10's w/ T-Lok coming in a few weeks.
http://www.mizzoustud.com/pics/conc.png
Concordium is offline   Reply With Quote
Old 03-22-2004, 09:34 PM   #5
McGrail482's Avatar
well would it be better to get just the crank pully or the water and alternator also?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 03-22-2004, 10:20 PM   #6
Rick0636's Avatar
Most just use a crank pulley on a V6, but you can use them all if you want. It all helps. The alternator one is overdrive and makes up for loss in alternator charging from the underdrive crank pulley. This helps for people with huge stereo systems etc.
Old 03-23-2004, 11:59 AM   #7
Concordium's Avatar
yup, what Rick said. i am getting the setup with the crank pulley, water pulley, and OD alternator pulley. but, i am only installing the crank and water pump pulley for now. you dont need an OD alternator pulley on a stock stang. i am saving the OD pulley for whenever i get a system put in my car. that way i dont have to order one and wait for it to come in the mail and install it. if your stang is stock and you have no plans on getting a system put in then go ahead and just get the crank and water pump pulley.
Silver '96 V6
Old 03-23-2004, 12:18 PM   #8
Danger Dude's Avatar
When you get a Crank pulley it slows down the water pump and on a stock alt pulley with a UDP at idle the lights do go dim at night and the alt is not putting out any positive voltage for charging!!!!
Old 03-23-2004, 12:56 PM   #9
Concordium's Avatar
yes, that happens when you are at idle. now imagine if i had a thumpin system in the car
Silver '96 V6
Old 03-23-2004, 04:01 PM   #10
Yes I have had thumpin sound systems in my cars but I have a thumpin sound coming from my cam that is the sweetest music to my ears !!!!!
Old 03-23-2004, 05:02 PM   #11
camming =
-Tony
'99 cobra 'vert
Old 03-23-2004, 09:48 PM   #12
Originally Posted by 01mineralgrey6
camming =
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 03-23-2004, 10:01 PM   #13
Region: New Hampshire
Send a message via AIM to Smokedya95stang
I have a system in my car and a udp crank and a udp alt pulley...
I dont notice any difference in charging. Even in traffic.. long trips.. idling..
no dimming of anything whatsoever.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 03-23-2004, 10:02 PM   #14
Btw: the'll require shorter belts..
96.0" - 96.8" will work fine.
-Charles
Old 03-23-2004, 10:08 PM   #15
You wont with the alt pulley speeding it up
Old 03-24-2004, 08:31 AM   #16
i had a underdrive alt pulley, not an overdrive alt pulley.
It was a kit from Hypertech, they dont make it anymore.
Plus when i switched alternators, i never switched pulleys. So whats on it now is a stock pulley.
-Charles
Old 03-24-2004, 08:32 AM   #17
Same goes for my friend scoprion99 and his system is larger than mine.
Alot larger..
-Charles
Cold Air Intake, ASP Pulleys, Diablo Tuner Matt@StangMods Mustang Parts for Sale and Wanted 0 06-13-2005 06:11 PM
brand new 01+ ASP UDP greystang3.8 Mustang Parts for Sale and Wanted 2 04-29-2004 09:58 AM
99-00 ASP pulley install JoeR. Pre-2005 V6 Mustang 5 12-11-2003 07:41 PM
just ordered an ASP pulley and belt off of RPM-mustangs. MusclesFromBrussels Pre-2005 V6 Mustang 17 08-18-2003 11:58 PM
06:36 AM
