What is pinging? - Mustang Evolution
Old 03-22-2004, 02:58 PM   #1
What is pinging?
what is it? How is it caused?
decsribe in great detail?
Trying to learn!
MustangNewB is offline   Reply With Quote
Old 03-22-2004, 03:05 PM   #2
Rick0636's Avatar
It is a noise made by an engine caused by too low octane fuel. This can actually cause severe engine damage in worst cases, up to and including holes in your pistons. You shouldn't have to worry about this unless your car has a performance chip or high compression pistons or possibly shaved heads. A stock Ford 3.8L engine is designed to run on 87 octane fuel and any higher than this can actually be bad for your car.
Old 03-22-2004, 08:00 PM   #3
Concordium's Avatar
actually there is more to it than that. pinging can be cause by detonation. detonation is when unburned fuel spontaneously explodes. this will pretty much destroy your engine and will cost you a pretty penny. detonation can be brought on by using high compression with low octane fuel or using a blower of some kind with low octane fuel. the thing is, if you have been putting premium fuel into your car and then revert back to 87 octane, your car will start to ping. simply continue putting premium fuel in your car and it should go away. but remind yourself to not put any higher grade than what your car needs.
if your engine detonated then you are gonna need to buy a new motor. so i hope it was just brought on by the fuel thing.
Silver '96 V6
Mods: True Dual Exhaust, Flowmaster 40's, Cobra Diamond Clear Headlights and Side Markers, Shortened Antennas, Blue Dome Light, Metallic Blue Painted Calipers, 4.10's w/ T-Lok coming in a few weeks.
http://www.mizzoustud.com/pics/conc.png
Concordium is offline   Reply With Quote
Old 03-22-2004, 08:14 PM   #4
tire's Avatar
Send a message via AIM to tire
concordium pretty much has it. never go below the octane your car is designed to use or your chip specifies.
tire is offline   Reply With Quote
Old 03-22-2004, 08:23 PM   #5
Rick0636's Avatar
Wrong dude, pinging, is detonation, just a milder form of it, and I think I already pretty well explained what causes it. Its not caused by going to a fuel that is too low of an octane, though it could be. In the case of a stock 3.8 Mustang the engine is designed to run on the lowest octane that is sold, if you are running more than that, you are just waisting money, and maybe damaging your engine. The only things that can cause the engine to need higher octanes are increasing compression, or advancing the timing with a performance chip, or if you have a 4.6 with a timing adjuster. The ways compression can be increased are with high compression pistons (domed) shaving the heads to increase it, or as you said, adding boost with a supercharger, turbo etc. If you increase the pressure in the cylinder then you will need more octane to slow down the burn, slower burns from higher octane stop detonation from fuels. Also I believe when I said detonation could damage an engine to the point of holes in the pistons, that pretty well destroys it.
Old 03-22-2004, 08:35 PM   #6
Concordium's Avatar
the way you explained it seemed that running premium fuel would cause the damage to happen to your car. you did not mention the word "detonation" in your post at all. running high compression/boost in your car along with low octane causes detonation. but you didnt specify that detonation was the direct cause of pinging. maybe it was a typo, but i didnt see the word "detonation" at all in your post.
Silver '96 V6
Old 03-22-2004, 08:39 PM   #7
Rick0636's Avatar
I did specify that running higher octane fuel than necessary can damage your engine, and it can. I didn't say it caused pinging at all, I didn't mention detonation, he didn't either, he asked about pinging, and pinging is detonation, it doens't cause it at all, its just a mild form of it. Check my signature, I know what I am talking about here.
Old 03-22-2004, 08:41 PM   #8
Concordium's Avatar
so do i. nothing personal. because your car pings when it detonates. but whatever dude. its all good on this end
Silver '96 V6
Old 03-22-2004, 08:45 PM   #9
pinging is just the slang for pre-detonation. It sounds like your car "pings", it really sounds like you have some bibi's in a metal can and your shaking them around.
Pre-detonation is just that, when you car is detonating in the combustion chamber too early. This is caused by too high compression with low octance fuel, contaminants in the fuel/combustion chamber that would make it harder for the fuel to ignite, and similar problems.
To picture it, think of your piston going up and the fuel ignites before the piston has gone all the way up its stroke......hence pre-detonation.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 03-22-2004, 08:51 PM   #10
Rick0636's Avatar
Pinging to me would be milder detonation, but I could have my facts mixed up here too. Ever see one diesel when you cut it off? Used to be more common back in the mid 70s, things would sit there and run for a couple of mins sometimes after you killed the switch. I am 53, and I have always done a lot of my own car repairs and tinkering, I got my Associates in Applied Science in Automotive Systems Technology in 99 after I was already retired on 100% disability and have never really worked as a mechanic so I enjoy helping out on the Mustang forums as much as I can, I have been driving Mustangs off and on since I got my first one in 67.
Old 03-22-2004, 08:57 PM   #11
Rick0636's Avatar
Nicely worded Stangin99!
Old 03-25-2004, 09:07 AM   #12
Is this pinging?
After i shut my 1994 mustang off. I can hear these "ding, ding" noises afterwards comming from the engine bay.
Is that pinging?
Thanks for your replies, you guys are really helping me.
Trying to learn!
Old 03-25-2004, 09:54 AM   #13
BlueDonkey's Avatar
That's metal contracting as it releases heat, no?
BlueDonkey is offline   Reply With Quote
Old 03-25-2004, 10:12 AM   #14
Rick0636's Avatar
Correct, the exhaust system, or the cats most likely, one thing I remember seeing a lot was the a/c condesation hose dripping water on there making a racket.
Old 03-25-2004, 10:25 AM   #15
Danger Dude's Avatar
Yep that does make a racket especially if you park in a garage. Ford did a nice thing designing a A/C condensation hose to drip on the exhaust pipes. helps prevent water puddles on the garage floor in the summer with the A/C on.
Old 03-25-2004, 10:50 AM   #16
lol...
you'll hear pinging in the 2-3k RPM range usually, under load of course.
Sad thing is my car's so damn loud I wouldn't know if I was pinging like a mofo or not.
New Hottness
1999 V6 5-speed
Wrecked
Old 03-25-2004, 11:12 AM   #17
I liek gramer
WhiteStang99's Avatar
yeah, the noise ur describing is most likely the ac condensation dripping on the hot exhaust. i park in a garage and hear it all the time.
Old 03-25-2004, 12:02 PM   #18
ok thats good that nothigns wrong.
I never use the AC just to let you guys know. Its cold where i live.
Trying to learn!
Old 03-26-2004, 07:51 PM   #19
Rick0636's Avatar
If you use your defrost, your a/c kicks in periodically. If you dont' think so, just let the car run with the defrost on and watch the a/c compressor, with the hood up of course, lol.
Old 03-26-2004, 11:34 PM   #20
I liek gramer
hmm. didnt know that. guess ya learn somethin new everyday.
Old 03-28-2004, 08:27 PM   #21
Rick0636's Avatar
Yeah, I forget exactly why, I think it has something to do with keeping the windshield from fogging.
Old 04-07-2004, 10:55 AM   #22
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
How would using an octane rating that was higher than 87 damage your engine? Also Why would running premuim fuel for a while then require you to run premium fuel from then on?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-14-2004, 09:27 AM   #23
Send a message via AIM to Crispy
Question
How bad, and what can happen? I started out using 87 but my car seems to go through it like water, and since gas prices are going up, I've been buying 89 which is only $0.07 more, and I get way better gas mileage. Mods done on the car are intake headers and 2.25" H pipe with flowmasters.
Crispy is offline   Reply With Quote
pinging with my chip Sublime782 Pre-2005 V6 Mustang 4 07-17-2005 09:16 AM
04:25 PM
