single port or split port - Mustang Evolution
Old 10-09-2008, 05:01 PM   #1
How do you tell if its single port or split port i have a 97 3.8 l i think i have single if so what all do i need to switch that over and can i keep the same block.
97 stang is offline   Reply With Quote
Old 10-09-2008, 06:04 PM   #2
Re: single port or split port
you have a single port. you will need the split port top end including the heads, intakes, and supporting fuel rail/injectors. i believe thats all. yes you can keep the same block.
tigerfan2771 is offline   Reply With Quote
Old 10-10-2008, 06:26 AM   #3
Herbstang's Avatar
99+ heads (including valves/springs)
99+ lower intake
99+ upper intake
99+ EGR tube and valve
99+ Throttle Body
TPS sensor for TB
99+Throttle cable
Modified fuel rail
99+ coil pack and wires
99+ cooling hoses and pipes.
99+ head bolts/studs
94-98 IAC gasket
94-98 exhaust header/manifold gaskets
94-98 IAC the 99+ IAC have a different connector
And a bunch of misc parts I.E - bolts/gaskets etc
Old 10-10-2008, 07:10 AM   #4
the upper intake on a single port looks like a 5.0 upper intake and says 3.8L on it and the split port you can count the runners in the middle of it and is only on 99-04 mustangs.
Old 10-10-2008, 10:11 AM   #5
have you thought about doing the m90 swap instead? youll get a little more hp, but tons more torque. from what i hear, its a much cheaper swap.
Old 10-10-2008, 01:35 PM   #6
by the time you do the swap you might as well buy the entire souper coupe engine, there are M112 03/04 cobra blower swaps out there pretty cheap for single or split port intakes (replaces them anyway) and they are getting GREAT results, much better than the M90 supercoupe
Old 10-10-2008, 01:59 PM   #7
I'd stick with single port, port the heads and intakes, and be done.
Old 10-10-2008, 03:34 PM   #8
yea but you gotta get a custom fit adapter and a whole mess of other custom parts. in the end that will equal out to getting a new/ slightly used procharger or vortech. the parts for the m90 can be found very cheap. i thought all you need for that is the intakes and fuel upgrades? dont you keep the heads and everything else?
Old 10-10-2008, 06:51 PM   #9
what all do i need for the m90 swap and approximately how much will that cost?
split port swap rydog Pre-2005 V6 Mustang 4 07-25-2007 12:07 PM
WTB: '99-'04 Split Port V6 Dom Mustang Parts for Sale and Wanted 3 07-12-2006 11:46 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
split port upper intake jimmy_beaner Mustang Parts for Sale and Wanted 0 05-30-2006 09:08 AM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
11:36 PM
