Coolant Level Confusion - Mustang Evolution
Old 10-10-2008, 07:59 PM   #1
IMP
I just replaced the hoses, t-stat, radiator cap, and coolant in my 1995 V6 Mustang. I have been monitoring the coolant levels in both the radiator and the remote reservoir for about a week now. I notice that if I remove the radiator cap when cold, the coolant in the radiator is about 2 inches down creating an air pocket just under the cap. I filled it to the top and quick put the cap back on a couple of times, but air consistently remains below the cap after the engine cools down. The coolant level in remote reservoir seems to stay within hot and cold level marks. The cooling system does go through its cycles and keeps the engine cool. Two questions:
1.) If I keep adding coolant to the radiator to top it off when cold, should it ever get to the point where the level consistently stays at the top of the radiator filler neck such that no air is present in the system?
2.) When you top off the coolant in the remote reservoir, do you do this cold or hot?
IMP is offline   Reply With Quote
Old 10-10-2008, 09:27 PM   #2
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Re: Coolant Level Confusion
It is a closed system so, unless there is a leak, you can overfill. Also, you should always fill the reservoir when cold. Hence why the cap warns against opening while hot and the high and low marks are called the cold fill range
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Coolant Level sensor? 99 SVT Cobra 1996-2004 Mustang GT 3 08-20-2010 10:04 AM
Coolant level Foxone Pre-2005 V6 Mustang 3 10-13-2009 07:41 AM
4.2 swap confusion Ninethourpm Pre-2005 V6 Mustang 1 06-29-2009 07:38 AM
Tire Confusion.. charcoal Mustang Wheels & Tires 7 01-13-2009 03:31 PM
Need help with my confusion..... Vinnietbird 1979-1995 Mustang GT 16 02-16-2006 03:17 PM
01:09 PM
