Timing on my blinker is screwed up - Mustang Evolution
Old 03-27-2004, 01:49 PM   #1
Seph's Avatar
Question Timing on my blinker is screwed up
Anyway I can change the timing on my blinker? I thought the light was going to die, but I think that I accidentally did something so now my right blinker blinks faster than normal. Anyone know how I can change this? It's been bugging me for QUITE a while.
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 03-27-2004, 02:44 PM   #2
you sure the blinker actually works?
If you have the bulb disconnected, it'll blink super fast inside the car, but obviously not at all outside. Check to make sure the bulb is actually lighting.
Other than that I don't think you could change it without getting into the wiring of it.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 03-27-2004, 04:25 PM   #3
Ponycarman's Avatar
blinker speed changes used to be caused by bulb issues. If a bulb went out, or you plugged in a trailer (or extra bulbs) that'd make the rate change.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-28-2004, 01:00 PM   #4
Seph's Avatar
Hrm alright, someone told me the timing might be off, but yes it is blinking outside tho.
-Patrick
Old 03-28-2004, 04:22 PM   #5
Ponycarman's Avatar
Front and rear blinkers?
You got a hitch (I know)?
If that fails, then it might be the flasher itself. Do the turn signals and hazards blink at the same rate? If so, might be the flasher. I think th enewer Stangs use an electronic flasher instead of the old style thermal flasher and it uses one flasher for everything. The flasher is located in the passenger compartment fuse box.
Steve
1996 Mustang
1965 Barracuda
Old 03-28-2004, 05:19 PM   #6
Seph's Avatar
yeah they both WERE going very fast. Me and my dad checked it out and we figured out the problem. The rear right blinker was the problem, there's 3 lights in there and the middle one died. We went to Autozone and got it all figured out, put the new bulb in and sealed everything back up. Works perfectly FIXED! The only problem was trying to get the light off. It was kind of a ***** taking 5 screws off to remove the damn thing, we had to take the upholstery off by unscrewing 2 plugs to get to them. A lot of work to just replace a light bulb :-/
-Patrick
Old 03-28-2004, 10:06 PM   #7
Ponycarman's Avatar
Congrats on finding it.
Steve
PS: I am a fan of redheads too.
1996 Mustang
1965 Barracuda
Dont forget to top off your blinker fluid! sonic04edge The Bar 11 03-01-2009 10:05 AM
Maybe I Need Blinker Fluid nay's mustang 1979-1995 Mustang GT 6 02-10-2009 04:50 AM
Changing front blinker bulb? jmy2469 2005-2010 Mustang GT 8 06-04-2008 11:00 AM
My blinker is having a seizure Brent Pre-2005 V6 Mustang 24 05-04-2004 02:02 PM
Anyone low on blinker fluid? Smokedawg The Bar 7 02-21-2004 01:07 PM
08:24 AM
