BBK 70mm Throttle Body install - Mustang Evolution
Old 10-11-2008, 07:45 AM   #1
rstewart's Avatar
I just installled a bbk 70mm TB and I am having some issues. I think it is related to Voltage but not sure. Has anyone installed one of these?
Isuues are engine light and the wrench come on. It starts fine and when I push on the gas pedal then these lights come on. I can clear the trouble codes with my diablo tuner and all is fine for a few minutes then the lights come back on. When the lights come on the car acts like it is staving for fuel or air.
any help would be appreciated.
Thanks.
2005 Mustang V6 - K&N CAI
BBK 70mm Throttle body
Diablo 93 octane Tune - 4:10 gears w/T-Lok - Pypes shorty headers, pypes X-pipe, pypes dual exhaust-Rear wheels-18x10 chrome deep dish Bullitt
Front wheels-18x9 chrome deep dish Bullitt
Tires - Nitto 555's
rstewart is offline   Reply With Quote
Old 10-11-2008, 08:04 AM   #2
Re: BBK 70mm Throttle Body install
The S197's really need adjustments in the tune with even minor bolt-ons.
I'd talk to whoever setup your diablo and have them adjust the tune for this 70mm TB and it should fix the problem.
Old 10-11-2008, 09:19 AM   #3
rstewart's Avatar
That is one avenue I will explore. But, I think it is voltage related due to the bfact that when I first installed the TB it would not even start. Second when I adjusted the idle screw on the TB it started and ran fine for a few minutes.
I guess what I really need is what the correct voltage for the TB.
After I get done here I will contact both BBK and Diablo to see if there are any leads or solutions there.
Thanks for the post. It is appreciated.
Tires - Nitto 555's
Old 10-11-2008, 05:20 PM   #4
rstewart's Avatar
I got it fixed - it was voltage. It runs like a charm now
Tires - Nitto 555's
Old 10-11-2008, 08:46 PM   #5
did you actually notice any gains from this? just out of curiosity.
tigerfan2771 is offline   Reply With Quote
Old 10-12-2008, 05:29 AM   #6
rstewart's Avatar
There appears to be gain at mid to high RPM. I won't know for sure untill I get it on a dyno.
I'll post the results as soon as I get in on the dyno.
Tires - Nitto 555's
Old 11-13-2008, 09:50 AM   #7
rstewart's Avatar
Smile Re: BBK 70mm Throttle Body install
There were minor gains in HP when I had it on the dyno, but it was probably due to tempature rather than the TB. Bottom line is that I think that the only time you will see larger gains is with a supercharger installed.
It does look nice though.
Tires - Nitto 555's
Old 11-13-2008, 10:56 AM   #8
Herbstang's Avatar
What was the gain ??
Old 11-13-2008, 01:51 PM   #9
rstewart's Avatar
6 hp
Tires - Nitto 555's
Old 11-13-2008, 02:42 PM   #10
Herbstang's Avatar
Beat the hell out of a sharp stick to the eye
Old 11-18-2008, 12:48 PM   #11
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
6 hp
cool thats 6more hp then the next guy
SaturnMan8227 is offline   Reply With Quote
Old 11-18-2008, 01:16 PM   #12
rstewart's Avatar
yes, but the next time I get on a dyno it could be right back where I started from. 6 hp was just not enough to tell the difference. I am supposed to go to florida this winter so I will try to get to a drag strip and do 1/4 mile times which I will not have the opportunity to do at home before the snow flys.
Tires - Nitto 555's
70mm V6 throttle body help skylar1926 Pre-2005 V6 Mustang 23 09-02-2004 09:17 PM
$150 For Sale NEW BBK 70mm throttle body for 3.8L V6 2001-2003 bumlebee Mustang Parts for Sale and Wanted 2 07-31-2004 10:54 AM
02:59 PM
