car sits higher any ideas? - Mustang Evolution
Old 03-29-2004, 06:48 PM   #1
the only mods i have done is a new set of tires and mm cc plates. I put on the cc plates and yokahomma es 100 275/40/17s and seemed to have gained an inch over my kumo 712 275/40/17s... not that either of the mods above had anything to do with the change in height but its the only changes that have been made to the car..... the front is now half an inch higher than it was before.... the only thing i could think of is the bump stops on the shock is binding but i dont see how since the car rides perfectly fine.... any ideas on why the car sits higher?
Old 03-29-2004, 06:51 PM   #2
Unless something got caught when you lifted the car to mount the new tires...but it would ride differently...no idea man
Old 03-29-2004, 07:04 PM   #3
01mineralgrey6's Avatar
could it be the tires??depending on how far down the kuhmos were worn. I have put tires on cars at work that come in with bald tires(not saying yours were) and when you mount the new tires on it sits higher. Im willing to bet that its the tires., Its also possible that the sidewall might look differant(design, etc) giveing the illuision of it sitting higher.
-Tony
'99 cobra 'vert
Old 03-29-2004, 07:14 PM   #4
Zim
You want to **** me?
Zim's Avatar
id agree with tony, maybe the added tread boosted it up a half inch
I like toys
Old 03-29-2004, 07:36 PM   #5
I liek gramer
WhiteStang99's Avatar
maybe u got shorter.
Old 03-29-2004, 07:57 PM   #6
Monkey's Avatar
the car just wants to be a 4x4 again. plain and simple.
Old 03-30-2004, 10:32 AM   #7
but at least I have 11 inches of ground clearence again
Old 03-30-2004, 11:39 AM   #8
tire's Avatar
Send a message via AIM to tire
i installed some caster/camber plates a few days ago on a friend's car and his car was the same before/after. i don't think there's any way to mess with the struts to preload them to ride high like you can with shocks?
tire is offline   Reply With Quote
Old 03-30-2004, 03:55 PM   #9
new tires..
you can get variations in tire size [although its very small] from one company to another..also note that some companies have stiffer sidewalls than others..so they will sit higher...ex: michelin tires have a very soft side wall and yokahoma's are pretty stiff, michelin likes to have soft sidewalls because it helps the everyday driver feel like he has a good ride, but they usually wear out fast also.....
vdog is offline   Reply With Quote
Old 03-31-2004, 01:03 PM   #10
OR_Red98's Avatar
Region: Oregon
It's really simple, the tires you put on are 2" taller than stock. A 245X40 is the proper size. Not to mention that your speedo accuracy is way out there somewhere.
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
Old 03-31-2004, 01:06 PM   #11
275/40 is almost perfect in diameter as a 245/45 which is the proper size for the 17s, but hieght does differ from brand to brand
-Tony
'99 cobra 'vert
Old 03-31-2004, 02:27 PM   #12
OR_Red98's Avatar
Region: Oregon
I'm not sure, what is the stock size for a 99+?
Old 03-31-2004, 06:20 PM   #13
um...... my tire sizes are right on 275/40/17 has the same over all diameter as a 245/45/17..... so its not the tire size... and my speedo is right on the money.
Old 03-31-2004, 06:57 PM   #14
Warfire80's Avatar
Send a message via MSN to Warfire80
lol
2007 Honda Civic EX
2003 Dodge Ram Hemi 4x4
by Lawrence Bell
Show me a man who cannot bother to do little things and I'll show you a man who cannot be trusted to do big things
Warfire80 is offline   Reply With Quote
would higher octane gas? help? Scorpion1 Pre-2005 V6 Mustang 16 06-28-2008 03:42 AM
Car ideas under $20,000 Monkey The Bar 15 11-22-2005 01:03 PM
Higher RPM's Due to Electrical Load? Rellik Pre-2005 V6 Mustang 11 03-30-2005 09:45 AM
need to make left headlight aim higher tedness Mustang Audio & Video 10 02-13-2005 07:27 PM
Gas price, any higher than me? NorwegianMustang The Bar 27 01-14-2005 06:26 PM
05:08 PM
