Excessive road noise; cause? - Mustang Evolution
Old 04-01-2004, 01:42 PM   #1
BlueDonkey's Avatar
Recently I've noticed some noise; it appears to be coming from the passenger side front wheel. It sounds a lot like tire noise (pitch and intensity are related to speed). However, the noise has persisted through a wheel and tire change and front alignment. Also, the noise lessens when I make right turns, and I can feel a vibration in the gas pedal around 50mph.
Any ideas on what's causing it?
BlueDonkey is offline   Reply With Quote
Old 04-01-2004, 01:44 PM   #2
Don't know how to help you short of someone sticking their head in your wheel well on a road test...
Old 04-02-2004, 02:59 PM   #3
Shahrum's Avatar
Send a message via MSN to Shahrum
This sounds like what happened to me over the summer. I drove thru an unmarked parking lot that had just layed down asphault to fill in cracks. That asphault hardened up on my tires which caused not only noise.. but a ton of vibrations and instability at 50+ mph speeds. Check to see if there is any debris on that tire.
Shahrum is offline   Reply With Quote
Old 04-02-2004, 05:34 PM   #4
Send a message via Yahoo to BlkStang4Me
Since you've mentioned that you have changed out the tires and the noise persisted, it sounds like your wheel bearings either need to be repacked or replaced.
BlkStang4Me is offline   Reply With Quote
Old 04-02-2004, 08:59 PM   #5
Shahrum's Avatar
Ah... my bad... didn't see the part about the new tires.
Old 04-04-2004, 11:05 PM   #6
BlueDonkey's Avatar
ok; how difficult is it to replace a front bearing, then? driveway project, or take-it-to-th-shop?
Looks like it's not hard, but the manual says to tighten the retainer bolt to ~260lb/ft!
Old 04-04-2004, 11:24 PM   #7
Region: New Hampshire
Send a message via AIM to Smokedya95stang
Where did you get your alignment done?
Take it right back to them and say that your front end is acting up, and you want to know what it is.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 04-05-2004, 07:11 AM   #8
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Wheelbearing. I had the same thing happen to mine. You can try taking off the spindle and packing it with grease. I did that to mine and it helped, but the growl didn't go away until I replaced it. The front bearings are all one peice with the spindle, so you have to replace the whole thing, which sucks. A new spindle will run you about $75. As I recall, you have to take the wheel off, the brakes and disk. Then get a big freakin' breaker bar and take off the nut in the center of the hub which is behind the domed, rubber covered cap that is in the center of the hub. You can pry that off with a screw driver if you're real carful. Try not to rip the crap out of the edges though. Just tap it under with a hammer and pry gently. With that nut off, the spindle comes off and you can replace it.
Oh, and when you take the calipers off, use some wire or something to support them out of the way. Don't let them hang from the brake lines. It's bad for them.
If I forgot anything, anybody feel free to fill in the blanks.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-05-2004, 11:34 AM   #9
I agree with Horse. You're biggest problem is going to break that nut free. I think my only concern would be making sure you got it on tight enough afterwards. You may want to check around at some local shops to see how much they would charge you to do it. I wouldn't think it would cost very much but you never know.
Old 04-05-2004, 12:26 PM   #10
Rick0636's Avatar
hit breaker bar with 2# or larger hammer, rather forcefully, it will loosen, and get tight. Don't think a torque wrench even goes as high as you quoted, if you have an air wrench turn it wide open and torque it to it!
Old 04-15-2004, 08:19 PM   #11
BlueDonkey's Avatar
Smile
Replaced the hub and bearing today, and no more racket. That seems to have taken care of it. Thanks all for the help.
Old 04-15-2004, 09:18 PM   #12
sweet, wheel bearings are easy.
-Charles
Old 04-16-2004, 09:11 AM   #13
Region: Iowa
Sweet, I was right... I'm getting pretty good at this car stuff.
Old 04-16-2004, 07:14 PM   #14
Awesome man! Glad you got it fixed.
Excessive inside rear tire wear CakeOrDeath? Pre-2005 V6 Mustang 14 12-14-2010 12:39 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Interior road noise doug89014 2005-2010 Mustang GT 6 04-19-2008 12:24 PM
No, seriously weirdest noise ever... Drunken Ghost Pre-2005 V6 Mustang 9 06-09-2006 04:52 PM
» Members Mustangs
Reptar
Adogg
"Red"
Labrat
Add your Mustang
11:17 AM
