How do you get a v6 mustangs wheels to both spin - Mustang Evolution
Old 04-01-2004, 10:06 PM   #1
hi i own a 94 v6 mustang and was wondering how do i get both rear wheels to spin when i burn out or what parts is needed to increase torque like maximum torque cause i wanna be able to do donuts like a gt mustang
chris_2004 is offline   Reply With Quote
Old 04-01-2004, 10:09 PM   #2
tire's Avatar
Send a message via AIM to tire
there's a part called a traction lock that acts as a clutch that will spin both wheels when the right one starts to slip. you can get them for 150 or less new but the install will be nearly as much unless you know people. if you do go for it and get it, go ahead and get some more acceleration by getting some 3.73 or 4.10 gears. you have 2.73:1 ratio now fyi.
tire is offline   Reply With Quote
Old 04-01-2004, 10:10 PM   #3
I liek gramer
WhiteStang99's Avatar
this belongs in drivetrain, but i dont have the power to move it....
you need a traction-lok, or t-lok. only one of your wheels will spin without it.
Old 04-01-2004, 10:11 PM   #4
Someone will give you links to sites that sell them I'm sure but if no one does i will get you some sites tomorrow with the exact parts you need
Old 04-01-2004, 10:12 PM   #5
if you're gonna put that in, you might as well get gears at the same time...and if you're gonna get gears go ahead an get a gt rear end, and while you're at it...just transplant the gt drivetrain over....nah i just kidding. I would get the gears while i was at it though
Old 04-01-2004, 10:31 PM   #6
Blue GT 5.O's Avatar
Send a message via AIM to Blue GT 5.O
do the 94 - 95 mustang gt wheels have the wheel lock already installed? i never have trouble with traction cept in the rain and my tires are bald as a freshlt shaved pu***.. :p
Justin "Boo" Lambright
http://www.mustang-forums.com/forums...ine=1082508257
Saphire Blue 1995 Mustang GT 5.0
Blue GT 5.O is offline   Reply With Quote
Old 04-01-2004, 10:50 PM   #7
Shahrum's Avatar
Send a message via MSN to Shahrum
I think all 94-04 v6's have a t-lok... just not one as good as the GT's.
Shahrum is offline   Reply With Quote
Old 04-01-2004, 10:57 PM   #8
tire's Avatar
blue gt, the wheels don't hold the traction lock. the tlok is located inside the pumpkin of the rear differential, in the center where it's fat between the wheels.
QUOTE=Shahrum]I think all 94-04 v6's have a t-lok... just not one as good as the GT's.[/QUOTE]
nah, no v6's ever have.
Old 04-02-2004, 09:38 AM   #9
Send a message via Yahoo to BlkStang4Me
I was searching the internet to try and find the cheapest priced gears and t-lok. I looked at rpmoutlet.com and they advertise that you need to get a modified cross-shaft as well. http://www.rpmoutlet.com/musv6fordgear.htm I haven't seen anybody else mention that here or advertised on any other web site. Can anybody help explain that?
Also curious if there is a difference between the Richmond gears and the Ford Racing gears?
BlkStang4Me is offline   Reply With Quote
Old 04-02-2004, 10:32 AM   #10
tire's Avatar
they both work alright, but ford's quality is better (believe it or not) and richmonds will tend to whine even if installed correctly. i thought about getting richmond 3.90:1's instead of ford 4.10's, but decided against it. (ford doesn't offer a 3.90)
Old 04-02-2004, 10:51 AM   #11
Rick0636's Avatar
I had a set of US Gear gears, they worked great, and didn't make noise at all, but they wound up costing me extra labor cause the guy had to take it apart and modify some kind of pins to make it work, better to stick with FMS gears. They fit right and work right every time. If you have lots of miles, say 40K plus even, go ahead and replace all the bearings and seals and all in there, you will be glad you did, less problems later on. Oh, by the way, www.differentials.com, or www.gefracing.com are good places for the parts man. Another good option is to replace it with an 8.8 rear end with the gear ratio you want in there they all have the trac loc. You can get one from www.speedconcepts.net I believe. Good Luck!!
Old 04-02-2004, 08:08 PM   #12
thanks for all your advice guys , but also another question see ive driven a v6 and a gt and i was wondering why does it always in a gt feel like its pushin in the back like the power is coming from the back more than a v6 like is it cause of the power difference..and if i have a 250 hp v6 will it feel the same as a gt or what parts do i have to change
Old 04-02-2004, 11:18 PM   #13
Send a message via AIM to PhantomGT
The extra 70 HP a GT has makes and 2 more cylinders a large difference. When you swap your gears out you won’t notice it as much.
I picked up some 3.73's and t-lok from GEFRacing and I say they are worth it
2001 V6, Way Beyond Stock...
http://www.mustangmods.com/data/2939/sig.jpg
PhantomGT is offline   Reply With Quote
Old 04-06-2004, 10:04 PM   #14
Send a message via AIM to 232SCstang
dude phantom your burnout there in the pic looks like you just let off of a brakestand while still holding the gas.
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
Old 04-06-2004, 10:10 PM   #15
I liek gramer
lol
Old 04-06-2004, 10:35 PM   #16
Cool
just got my 4.10 w/ t-lok installed in my 95 with auto trans....it's a v6....
it will now spin both tires ....and goes from zero to 60 faster..the traction-lock works very well......
and I'm digg'n it.....ricers beware....
vdog is offline   Reply With Quote
Old 04-07-2004, 10:46 AM   #17
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Does anybody know what that modified cross shaft is for?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
v6 mustang
MD mustangs? steedav6builder Regional Mustang Discussion 0 04-03-2010 07:19 PM
Looking to trade my wheelzz saleen wheels!! Wtt 4 blk wheels saleenman Mustang Wheels & Tires 12 08-27-2009 12:41 PM
Spin-Tech Sportsman Street Mufflers? SilentNoise 1979-1995 Mustang GT 0 04-02-2007 06:15 PM
Mustangs & Mustangs Car / Airplane Show This Saturday in FL JasonVMP Regional Mustang Discussion 2 03-29-2006 04:12 PM
08:03 PM
