I now have a pile of engine parts on my workbench - Mustang Evolution
Old 04-02-2004, 10:53 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
My passenger side headgasket started leaking like a siev. I started buring oil and the SES light came on, the whole works. Anyway, so I've got to replace them. I figured as long as I had torn it down that far I might as well put it back together better than it stared so I decided to get some nice ported heads. Since I was so close Mikael at RPM talked me into a cam (really didn't have to twist my arm). Acctually I'm incredibly impressed with him. As I was ordering my heads, he told me that what I was getting was overkill for what I have, and that I'd get better gains with cheaper heads and a cam. His suggestions saved me several hundred dollars. I applaud him for being so honest.
Anyway, I've got the engine torn all the way down to the block now, and I have a 4X8 sheet of plywood as a bench totally full of piled engine parts... I tell you it's down right creapy. My poor car looks like a gutted corpse.
Hopefully it'll only be a week or so more until I can get all my new parts. With any luck I'll be able to have him back together before the first autocross of the season on the 18th.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-02-2004, 10:57 AM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I think we need a picture of this 4x8 piece of plywood
Rellik is offline   Reply With Quote
Old 04-02-2004, 11:36 AM   #3
tire's Avatar
Send a message via AIM to tire
good luck horse, if it's not your daily driver, there tends to be this thing called laziness that starts to set in after a while... don't succumb!
just curious, but was your motor stock when the head gasket went? that's not good to hear!
tire is offline   Reply With Quote
Old 04-02-2004, 12:29 PM   #4
Shahrum's Avatar
Send a message via MSN to Shahrum
Well... since mostly everything's out... might as well put a V8 in there
Shahrum is offline   Reply With Quote
Old 04-02-2004, 03:37 PM   #5
Region: Iowa
Cool
It is my daily driver. I can't wait to have my mustang back. The Saturn I'm borrowing from my parents sucks.
Anyway the gasket that let go on me was the one that came with the engine. I've never had the heads off before. The only changes to the engine are a CAI, underdrive pulley, and ported upper and lower intakes. Oh and a breather filter to fix the ****ty PCV valve problem. Just capped off where the tube hooked up to the upper intake.
I'll see if I can borrow a digital camera from my friend to get a picture of the carnage.
Old 04-02-2004, 09:05 PM   #6
Region: New Hampshire
Send a message via AIM to Smokedya95stang
werd, pics!
-Charles
Smokedya95stang is offline   Reply With Quote
Old 04-06-2004, 08:12 AM   #7
RGR
Send a message via AIM to RGR
Actually, it is dumb for us (V6 shops) to sell over-ported
heads and huge cams, because the engine will not run right
and make less overall power, get bad mileage, bad emissions, etc...
A properly sized cam and properly ported heads will kill an "overkill"
engine any day, in a street car setup. That is why I do the cam form
and work out a whole combo...
Mik tries to follow my example
I've seen bad overkill on 99^ V6's, they just will not run right if over-cammed and over-ported.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 04-06-2004, 10:41 AM   #8
and work out a whole combo, Mik does so too.
In the past I wondered if something in my combo was overkill..
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 04-06-2004, 10:48 AM   #9
RGR
what are the mods again?
Old 04-06-2004, 02:45 PM   #10
for the engine..
RPM Heads/lower, 207/215 cam .493/.495 112lca, udp, cai, duals, self ported upper.
New Hottness
1999 V6 5-speed
Wrecked
Old 04-11-2004, 07:59 AM   #11
RGR
Probably not, except the cam needs less exh. duration.
unless you plan on an SC later, I would do it different now
but I've seen many combos with porting and cam just flop...
Old 04-11-2004, 12:14 PM   #12
boost is a dream right now...who knows if I'll ever do it.
Like I said somewhere else..I may want you to re-spec a perfect cam for this engine this summer.
New Hottness
1999 V6 5-speed
Wrecked
Old 04-11-2004, 12:16 PM   #13
Zim
You want to **** me?
Zim's Avatar
:worthless:
I like toys
Old 04-11-2004, 02:19 PM   #14
RGR
haven't U ever seen a pile of single port engine parts? :swordfigh
Old 04-23-2004, 03:19 PM   #15
Region: Iowa
The parts are here!
My parts came!... new ported heads, gaskets, head bolts and a cam!
SWEET!
Old 04-24-2004, 06:49 AM   #16
Send a message via Yahoo to 98GreenStallion
SWEET!
Thats awesome man!
Now all you need to do is take some friggen pics!!!:p
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 04-26-2004, 10:54 AM   #17
Region: Iowa
PICS!
Thanks to my friend Warlock, pics are up here: http://www.warlockweb.org/gallery/gallery/headinstall
Sample:
~This post is brought to you by Horse's secretary, since he's so covered with corrosive fluids from putting this mess back together that he can't type.
Old 04-26-2004, 11:44 AM   #18
Zim
Zim's Avatar
sheesh! hope you get her runnin soon
I like toys
Old 04-26-2004, 12:09 PM   #19
Tbird232ci's Avatar
i guess i gotta put all my car parts on a table and take pictures now
Old 04-27-2004, 07:12 AM   #20
Region: Iowa
My car is over half put together. I have gotten the head gaskets, heads, headers, lifters, lifter retainers, pushrods, rocker arms, radiator, power steering pump, alternator, A/C, cam, timing chain, timing cover, cam position sensor, water pump, oil pump, the reserve tank bracket, and the trim plastic over the radiator all installed. I'm going to be dedicating my Wednesday night to putting in the lower intakes, fuel rail, injectors, upper intake, all the radiator hoses, EGR piping, valve covers, coil pack, spark plugs, oil filter, all the emmissions tubing and vacuum lines, random electronic sensors and various other crap. Working on cars is fun, but since it's mine I JUST WANT IT TO BE DONE!
Old 04-27-2004, 10:46 AM   #21
Region: Iowa
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
polishing engine parts? tedness Mustang Audio & Video 32 10-26-2005 12:54 PM
various v6 engine parts knife13 Mustang Parts for Sale and Wanted 0 03-02-2005 06:26 PM
added to the pile today - in-dash gauges w/ bezel fast64 Pictures and Videos 6 01-24-2005 11:15 PM
questions about engine parts Johnny D Pre-2005 V6 Mustang 3 02-08-2004 12:03 PM
09:02 PM
