door lock problems - Mustang Evolution
Old 04-03-2004, 11:09 AM   #1
I liek gramer
WhiteStang99's Avatar
Exclamation door lock problems
I need information reguarding any of the following:
-The location of the factory security controller for a 99 stang
-Info on connecting an alarm into the lock and unlock wires, I have lock working but unlock not working
-Info about switches ceasing to work once locks wires have been messed with(not broken or disconnected and fuse is good)
Please reply ASAP!!
Thanks
Old 04-03-2004, 11:57 AM   #2
LuvMyGT's Avatar
Send a message via AIM to LuvMyGT
Please reply ASAP!!
Thanks
Let's get a couple things straight first. I am assuming you unplugged your battery before you started? Did you check both your fuse boxes? I am guessing that one or more wires have come undone when you tried to put everything back together. Are you using crimpers or electrical tape? Don't use tape if you are, it won't hold it well enough on the re-install. How many times have you disassembled them and checked them? If you've only done it once, do it again and check them thoroughly. Make sure the alarm you are installing is compatable with your car. The factory security controller should be located inside your steering column just behind the ignition switch. To install something such as a remote-start, you will have to remove the chip from your key and fasten it inside your steering column against the security controller to bypass the device or your car won't start. Whoo, that was a mouthful. Let me know if you still have problems. I'm not positive exactly what you are needing for sure, but I can help you track down the right sources.
LuvMyGT is offline   Reply With Quote
Old 04-03-2004, 01:08 PM   #3
I liek gramer
thanks, its my friend that posted that. ill go out and let him know what you said.
Old 04-03-2004, 01:42 PM   #4
LuvMyGT's Avatar
No problem. Let me know how it turns out....or if it turns out.
Old 04-03-2004, 02:38 PM   #5
I liek gramer
blah, we're working on it. Remote start works!
Old 04-04-2004, 06:26 PM   #6
While I have nothing to contribute to this thread... I do love remote start.
Laser02 is offline   Reply With Quote
Old 04-05-2004, 03:15 PM   #7
I liek gramer
im takin all of it off. learn from your mistakes....
Old 04-05-2004, 03:15 PM   #8
I liek gramer
oh yeah, we did fix the doors.
Old 04-05-2004, 03:47 PM   #9
Zim
You want to **** me?
Zim's Avatar
what was the problemo?
I like toys
Old 04-06-2004, 04:36 PM   #10
I liek gramer
our wiring guide was incorrect. But then the blinkers quit working. Then located the blown fuse. And now no CRUISE CONTROL! :cussing: :arg: :angryfire :thumbsdow
Any ideas...? I didn't see a fuse for Cruise in my manual, but I hope I just overlooked it.
That Fvcking alarm is coming out tomorrow.
Door Lock Trouble pmushock 1996-2004 Mustang GT 4 04-24-2009 08:16 PM
Door switch problems. matthews.stang Pre-2005 V6 Mustang 2 06-04-2007 08:39 PM
Door Panel Problems Justin 1979-1995 Mustang GT 8 10-11-2006 01:51 PM
need help changing door lock cylinder on my 98 dvon1981 The Bar 7 09-25-2006 03:20 PM
Sprayed in bedliner and billet fuel door with lock... Rick0636 The Bar 21 08-06-2005 11:42 AM
06:43 AM
