grinding sound, stiff breaks, and loos of power wile driving - Mustang Evolution
Old 04-04-2004, 05:48 PM   #1
Send a message via AIM to blk2kconvstang
i need some help, today my car started acting up. i was driving home on the highway and got cought in some traffic getting onto 95 off 495 and when i was going slow (15mph and slower) my car makes a grinding sound every time the tire goes around and my breaks are realy stiff and it feels like i have a loos of power as if my foot is resting on the break pedel wile i'm driving. what would cause this too happen? (oh and when i go slow in revers i get a constant rubbing nois that is prity faint) PLEASE HELP ME
blk2kconvstang is offline   Reply With Quote
Old 04-04-2004, 06:00 PM   #2
Your caliper is seized.
Or your rotors are really messed up.
I had the same thing happen to me. Except my rubbing noise wasn't very faint in reverse.
Laser02 is offline   Reply With Quote
Old 04-04-2004, 08:50 PM   #3
yea, its the rear driver side. i didnt realize it before but i washed my car yesterday and i went out and looked at my rims and all of them are clean accept the rear driver side,it was break dust all over it, and that is the one that is rubbing. (i had my roomate drive slow wile i walked next to the car and that one is constantly rubbing) thanks for the help!
Old 04-04-2004, 11:02 PM   #4
BlueDonkey's Avatar
had that happen laast summer; front driver side caliper seized. Lots of dust, stink, and heat. Not difficult at all to replace, tho.
Which 95/495, if I may ask?
BlueDonkey is offline   Reply With Quote
Old 04-05-2004, 07:20 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
You'll need a new caliper, and you'll need that rotor machined. Probably cost you around $20 or so to have that done.
Not sure how much a rear caliper is. I had mine stick once. I took it off, and cranked it back in and then it worked. To compress the rear calipers you ahve to screw them in. There's to notches on the top of the piston and if you have a big set of needle nosed pliers you can use them to turn it. It's a really fine thread so be preparted to crank on it for several minutes. They make a tool for it I think, but big pliers work ok.
good luck
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Weird Grinding Sound? Gt.Vert 1996-2004 Mustang GT 2 01-14-2010 01:31 PM
grinding sound elystarz New Member Introductions & Greetings 1 08-15-2009 06:57 PM
odd sound. power steering pump? one swell foop Pre-2005 V6 Mustang 6 06-21-2005 07:35 PM
Power Vs. Sound munny 1979-1995 Mustang GT 8 03-13-2005 12:36 PM
10:27 PM
