Need help and input fast - Mustang Evolution
Old 10-16-2008, 05:38 PM   #1
Send a message via AIM to wh!te_stang Send a message via Yahoo to wh!te_stang
ok i just bout a new pulley kit (water pump pulley and crankshaft pulley)
so i drove it the first couple of days and it was amazing but after about three days my battery went completly dead so i bout a new Optimum battery ($200) but after two days the battery light was flashing so i got the altinator tested and they told me that it was sending amprage but no voltage if i buy a new altinator should that solve my problem or is there more to pulleys that I am not aware of and will cause more issues?
cuz if so i might just put the stock ones back on and kiss the extra horsepower gains good bye
wh!te_stang is offline   Reply With Quote
Old 10-16-2008, 05:42 PM   #2
1234's Avatar
Re: Need help and input fast
stick or auto? first off.
Old 10-16-2008, 05:43 PM   #3
automatic
Old 10-16-2008, 05:43 PM   #4
1234's Avatar
And amprage but no voltage makes no sense. you cant have amps with out volts. volts push the amps to their destination.
Old 10-16-2008, 05:44 PM   #5
1234's Avatar
they make a different pulley kit for the autos. You might look into that. But if you take the alternator off and tak it to have it tested they would be able to tell you.
Old 10-16-2008, 05:49 PM   #6
Well i already ordered a new alternator.... should that solve my problem with my battery draining or should i also be aware of some other issues?
Old 10-16-2008, 06:12 PM   #7
1234's Avatar
The pulley kit would be the only thing i would look at it the new alternator doesnt work.
Old 10-16-2008, 10:05 PM   #8
thanx ill keep you posted and let u know how things work out
Old 11-02-2008, 01:54 AM   #9
everything worked out wit da new altanator!!!!! thanx 4 da help
Old 11-03-2008, 11:25 AM   #10
1234's Avatar
Not a problem glad that fixed it.
brakes - need input sledgehammer Pre-2005 V6 Mustang 5 03-05-2008 03:04 PM
Want some input iwannagofast The Bar 11 11-23-2007 04:23 PM
Need some input... crazeflier07 Mustang Wheels & Tires 6 10-03-2006 08:57 AM
fast and furious 3- fast food run Kyle The Bar 7 04-13-2006 12:56 AM
Your input is valuable John Kerry The Bar 33 09-18-2004 10:02 PM
02:27 AM
