lower intake porting question - Mustang Evolution
Old 04-06-2004, 03:31 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
When porting out the short runners on a 99+ lower intake, should you strive for the same diameter througout, or more of a funnel shape?
I have some lower intakes that weren't gasket matched because I didn't have ported heads when I got the intakes, but now I'm getting heads and I wanted to port the lowers to match.
Suggestions anyone?
Thanks.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-06-2004, 08:25 PM   #2
Send a message via AIM to cuban3jumper
I'm not 100% sure but I would think you would want a nice even porting all the way through. Just gasket match everything.
1999 4r70w 3.8L V6
1/8 mile: 8.9 @ 80 mph
cuban3jumper is offline   Reply With Quote
Old 04-06-2004, 09:35 PM   #3
you want to port match the lower to the heads, not gasket match.
As for the top of the lower...you should match that to your upper as well, might as well gasket match both.
it ends up more of a tapered effect on the long runners and gasket matched on the short ones.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 04-07-2004, 10:37 AM   #4
Region: Iowa
The upper, and the top of the lower (I think) are already gasket matched, so all I have to worry about is matching the size of the head port to the lower intake port.
Thanks
Old 04-07-2004, 11:20 AM   #5
Monkey's Avatar
keep it round and not tapered.
Porting upper and lower intake stangaroo Pre-2005 V6 Mustang 8 03-09-2010 01:55 PM
Lower Intake snake428CJ 1979-1995 Mustang GT 5 08-06-2008 10:17 AM
Hotchikus lower control arms question dana 1979-1995 Mustang GT 14 02-03-2006 07:58 PM
porting question Sublime782 Pre-2005 V6 Mustang 2 12-14-2005 03:12 AM
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 09:41 AM
03:45 PM
