Cruise quit working...... - Mustang Evolution
Old 04-07-2004, 05:13 PM   #1
I liek gramer
WhiteStang99's Avatar
:angryfire
I have a 99 v6 stang, w/ cruise, and it quit working. I'm about 99% sure it had something to do with that fvcking alarm I had installed, which is coming off.
:ar15::ar15: :ar15:ALARM!!!!:rockets:
It's been too much trouble. but anyways, is there a fuse I could check? I couldn't find one for cruise in my ford manual, but I only looked quickly. Any info is appreciated, esp if you know what # the fuse is and where, or what the book says it is.
If it isn't a fuse, which is what I'm afraid of... What would I have to do to get this fixed? I don't really have much $ :damnit:
Old 04-07-2004, 05:19 PM   #2
You don't need cruise...my car doesn't even have it at all. Just learn to control your ankle really well and you don't need cruise. Kinda hard to do when your right leg is in a cast up to your hip....but I got by.
Old 04-07-2004, 07:24 PM   #3
01mineralgrey6's Avatar
the back of the fuse panel should say where the fuse is. The other thing I could think of is possibly a relay.
-Tony
'99 cobra 'vert
Old 04-07-2004, 08:03 PM   #4
Rick0636's Avatar
I had a cruize quit working on an older model car once, turned out to be a vacuum line had come loose, not sure if ours have a vacuum line on them or not, but its worth looking into.
Old 04-08-2004, 10:13 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
If you have a manual, it might be the switch that monitors whether your clutch is pushed in or not. It's connected under the dash behind the clutch pedal. It's a plastic box with a plunger that is pushed in when the clutch is out.
Just a thought.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-08-2004, 05:25 PM   #6
I liek gramer
no, i have auto. thx tho.
It's not the fact that I just can't survive w/o cruise, but there are buttons on my steering wheel, and they better do somethin god damn.
I didn't see a fuse for cruise, like i said, i already looked. guess I'll pull them all one at a time and see what I come up with. Thanks tho guys. I just hope its something I can take care of on my own, cuz I'm broke.
Convertible Top Button Quit Working SuperDave2010 1996-2004 Mustang GT 3 07-06-2010 09:12 AM
Better quit using WEP... MarkuzLS1 The Bar 9 08-10-2006 07:35 PM
keyless entry quit working archer379 Pre-2005 V6 Mustang 7 09-19-2005 03:39 PM
So... I quit smoking... .:DarkEntity:. The Bar 27 08-07-2003 08:46 AM
12:30 AM
