Check engine light, codes inside, cause? - Mustang Evolution
Old 07-29-2003, 11:00 PM   #1
misfire code ????
why did u get codes out of your instrument cluster ??? Are u sure your low coolant light didnt come on and not your check engine light ??? not one of those was a misfire code a missfire code for #5 is P0305 the last number is the cylinder and there is no way u can get that from the instrument cluster If u thought it was that easy to run diagnostics and be able to interpret it your mistaken even if u get the right code and figure out what it means do u know how to fix it how r u going to monitor all of your pids ???? these codes dont tell u what to fix sorry not that easy lol i wish it was sometimes do yourself a favor and leave it to a cerified ford tech it will save u in the long run and why would u give your precioius stang to some joe blow anyway take pride in your vehicle
MUSTANGJUNKY420 is offline   Reply With Quote
Old 07-30-2003, 12:14 AM   #2
???? i took it and had the codes read it had a num 5 miss fire, miss signal actually from the crank sensor due to the pulley balancer not being on tight enough. I tqed it down hard as it should have been and the light has been off for a good while now.
Old 07-30-2003, 12:22 AM   #3
cool must have fixed it
check engine
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 10:12 AM
IAT inside intake pipe, still check engine light tedness Pre-2005 V6 Mustang 7 07-05-2005 08:30 PM
check engine light came on... red pony V6 Pre-2005 V6 Mustang 14 07-01-2005 08:24 PM
Check engine light SVT_Rob Pre-2005 V6 Mustang 6 06-01-2004 04:10 PM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
02:47 AM
