m90 supercharger question????? - Mustang Evolution
Old 10-18-2008, 05:16 PM   #1
im buying a m90 supercharger used what all will i need to do to put it on my 97 mustang 3.8l? I was also thinking about putting a ssm power pack on should i do that and if so what stage should i get?
97 stang is offline   Reply With Quote
Old 10-18-2008, 06:23 PM   #2
Re: m90 supercharger question?????
how much are you getting it for? are you going to get a blow off valve?
jkemerica is offline   Reply With Quote
Old 10-19-2008, 05:07 PM   #3
got the supercharger as it was bolted to a supercoupe everything is with it i dont know if it has a blow off valve with it . i payed 300 for everything did i get screwed. will the supercharger help me out with power or should i just get a ssm power pak and be good with that.
Old 10-20-2008, 11:19 AM   #4
1234's Avatar
If im not mistaken roots style blowers dont have blow off valves. They have bypass valves.
Old 10-23-2008, 05:48 PM   #5
i was thinking about getting a supercharger and they were all in the 2,000 where did you find one for 300? im not so sure about that
Old 10-23-2008, 09:24 PM   #6
m90's at 300 are not that uncommon...M112's for 400, 700-800 ported, are no uncommon.
Old 10-31-2008, 06:18 PM   #7
i would like to get one
Old 11-01-2008, 08:27 AM   #8
The problem with the M90 is for all the work you have to go through to get it all plumbed up it isn't worth the power. To be honest you can spend money on a set of ported heads with a nicely profiled cam and some longtubes underneath p/p upper and lower intakes and make more power more reliably all engine...
Old 11-05-2008, 09:03 AM   #9
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
I'm going with you on this one!
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 11-05-2008, 10:16 AM   #10
Herbstang's Avatar
Brad speaks the truth
Old 11-05-2008, 07:28 PM   #11
I was wondering about this also. ive got a 99 and i would like to put the M90 on it but what kind of work am i looking at? Do i need a different intake manifold? How does this thing mount to the engine? what other vital parts are needed to make this happen? I am clueless about supercharging and am just looking into it.
Joshbell is offline   Reply With Quote
Old 11-05-2008, 07:30 PM   #12
You will need new heads, new lower intake, and the complete supercharger setup....new injectors and a tune. It's a lot...you're better off finding a complete supercoupe motor and doing a complete motor swap instead.
Old 11-05-2008, 08:30 PM   #13
A viable option on the 99+ split port setup is the M112 Eaton kit. There is at least one company selling and all-in-one kit for the 99-04 Split Port 3.8 engines. Along with the M90 or M112 you will need fuel upgrades, a tune, and eventually supporting parts such as transmission work, rear end upgrade, and probably go ahead and plan on doing a bottom end engine build at some point in the future.
Old 11-07-2008, 06:26 PM   #14
i have a 3.8L 2002 mustang if i were to get a turbo would i have to get twin turbos one of my friends though so. also would i have to go threw all of that work too?
Old 11-07-2008, 06:50 PM   #15
You could just place a turbo randomly in the engine bay....otherwise you will need alot of custom piping, oil lines, tuning, fuel upgrades, etc etc etc etc....
Old 11-09-2008, 12:28 AM   #16
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
thats what id do, dont bother with a m90 roots blower on a v6 either, yea they are cheap but they arent even worth it at the end of the day.
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 11-17-2008, 04:40 PM   #17
Roadhawg's Avatar
I'm happy with mine.............
2003 Mustang Mach1
1995 Thunderbird LX 4.6
1995 Mustang 4.2; MPX Supercharger/25%OD
Roadhawg is offline   Reply With Quote
Old 11-17-2008, 05:47 PM   #18
1234's Avatar
^^Looks good.
What kinda numbers did you get out of it?
supercoupe m90 supercharger 3.8boii Pre-2005 V6 Mustang 4 04-19-2010 11:48 PM
Eaton M90 Supercharger CCT4132 Pre-2005 V6 Mustang 5 09-15-2009 03:46 PM
Roush M90 Supercharger SaturnMan8227 Pre-2005 V6 Mustang 2 02-06-2009 08:32 AM
Eaton M90 Supercharger for V6 Mustangs nmaraijko Mustang Parts for Sale and Wanted 10 08-10-2008 06:16 PM
eaton m90 question greenpony02 Pre-2005 V6 Mustang 10 01-23-2005 01:07 PM
08:15 AM
