***Underdrive Pulley Tech and FAQ*** Please Read - Mustang Evolution
Old 07-16-2003, 09:21 AM   #1
i have a 2003 6 5-speed what can i do?????
03zinc6 is offline   Reply With Quote
Old 07-16-2003, 11:02 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Do you mean, can you get a UD pulley? yes, you can. There's a link for 2001+ model years.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-29-2003, 11:28 PM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
i'm completely stock...
is this something i should get?
i'll hopefully be getting dual exhaust and a CAI before too long
are UDP something i need?
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 07-29-2003, 11:52 PM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
UDP are a great investment, if i started all over the UD will be first.
rev'ed faster and i loved it.
Def worth the money for 94-98's
It gets to be almost like 150-200 bucks for 99+ which is expensive. But they have been dynoed at ~8 rwhp.
I see you have a 97, its a great investment. You can get them for your year on ebay or wherever like extreme effects. for good prices.. like 50-90 bucks.
Go for it, it also an easy install. Esp with a impact wrench.
Rellik is offline   Reply With Quote
Old 07-30-2003, 12:04 AM   #5
dark's Avatar
thanks... i'll do UDP and CAI at the same time then
are there any adjustments not mentioned above that i would need to make?
Old 07-30-2003, 09:15 AM   #6
On the 97 Mustang, the UDP is probably the easiest install you'll ever do. You take off the belt, unbolt 4 bolts to drop the old pulley, bolt the new pulley in its place, and put on the new shorter belt. I did it in about 20 minutes on my 98 Mustang.
You're starting out the same way I did. My first mod was the CAI, then the UDP shortly afterwards. The 2 combined will let you notice your car "pep" through the RPM's a lot faster than they are now.
If you need any help, feel free to ask. We'll be happy to help ya . By the way... good choice on the 97... because 94-98 Mustangs are the best .
Old 07-30-2003, 12:03 PM   #7
YOu have to line up the pulley when you put it back on correctly or your car will run very ****ty.
Becarefull about that, people think this is the easiest install then the have a wobbly UD pulley.
hah
Its pretty easy, just dont slap it on make sure its straight.
Old 07-30-2003, 12:14 PM   #8
The wobbly situation you're referring to can be easily averted by tightening the pulley bolts evenly... just as you would lug nuts on a tire
Old 07-30-2003, 12:33 PM   #9
dark's Avatar
aight, cool. in 2 week i'll have UDP
:cooler:
Old 07-30-2003, 01:58 PM   #10
no rellik people have put them on like that, and it causes wobbly and horrible idle, loose belts. Bad stuff.
Like when you take off your stock pulley, and your going to reinstall it, always use a grease pen or chalk to notify where the bolts are located so it will go on straight.
Old 07-30-2003, 03:35 PM   #11
You're talking about 4 identical bolts.... you know that right Charles? :
Old 07-30-2003, 05:19 PM   #12
yes..... trust me............. ive done this before...
i've also taken my stock one off with my mechanic and he put it back on a while ago..
Old 07-30-2003, 05:20 PM   #13
I guess I just got lucky then. I just unbolted the old one, and bolted the new one back up with even TQ settings.
Old 07-30-2003, 05:26 PM   #14
It could be 'slightly off' and you may not even realize it.
But its ok just as long as your not terrbily off, and if you were you would notice it.
You see the pulley is connected to a Vibration damper. YOu want to mark the bolts and reasemble it as close as you can to the balanced damper. The pulley and damper are initally balanced as a unit so if you unbolt it and slap it on with out a care in the world it may not be balanced correctly to the damper .
Old 07-30-2003, 09:24 PM   #15
dark's Avatar
^how will i know which bolts to line up?
Old 07-30-2003, 10:57 PM   #16
Its really easy, when you take it off make little marks to match the damper.
Old 07-31-2003, 08:55 AM   #17
Make little marks to match the dampener? Charles, what and how would you use that on the new pulley? You have nothing for orinetation on the new pulley when you do that.
Here's my point in a diagram form. Maybe you can tell me the answer:
Old 07-31-2003, 09:01 AM   #18
dark's Avatar
haha @ i'm getting confused again
Old 07-31-2003, 09:14 AM   #19
Darkling, I dont know if Charles is referring the mark to the 99+ UDP's or the pre99's. From what he's saying making a mark on the dampener, I would assume he's talking about the 99+'s... but he's confusing me too, whats why I asked with a picture this time.
Old 07-31-2003, 09:32 AM   #20
evin, iam talking about 94-98s.. its not hard at all.
And yes you can mark it, its easy.
Old 07-31-2003, 09:33 AM   #21
So how could you explain the reference issue that I pointed out?
Old 07-31-2003, 09:44 AM   #22
easy. the ud pulley fits inside the crank pulley mostly.
Line up the bolts. mark both the pulley and vibration damper.
so it fits right on.
There are sensors down there as well. Be carfull guys... damn.....
Old 07-31-2003, 09:49 AM   #23
I'm just not getting it. sorry man. I'll drop it and leave it at that.
Old 07-31-2003, 09:50 AM   #24
dark's Avatar
the issue here is, how do i know where to mark the new pulley? as it's fresh out of the box. i'm assuming it doesn't come marked
Old 07-31-2003, 09:53 AM   #25
When you loosen the bolts make an outline of it on the stock pulley. transfer that to the UD pulley. Also make the same mark on the damper.
if the bolts are off a little, it could make the pulley crocked. Also use a torque pattern like when you change a tire.
Old 07-31-2003, 09:59 AM   #26
dark's Avatar
oh, so when i put the new one on, i take the old one off in 1-4-2-3 order, then when i put the new one on, i go 3-2-4-1 order?
Old 07-31-2003, 10:02 AM   #27
yea doesnt matter what order you go just dont go around.
Old 07-31-2003, 10:09 AM   #28
dark's Avatar
haha, alright, i've finally got it!
i'm not a slow learner, really
underdrive pulley blackonblack Pre-2005 V6 Mustang 17 12-29-2009 08:46 PM
Underdrive pulley obxdude018 Pre-2005 V6 Mustang 7 07-27-2009 04:07 PM
underdrive pulley Risingsun 1979-1995 Mustang GT 5 07-15-2009 10:13 PM
underdrive pulley STEVE Pre-2005 V6 Mustang 12 06-27-2004 02:20 AM
Underdrive Pulley 3Point8 Pre-2005 V6 Mustang 16 03-25-2004 06:52 AM
07:47 AM
