What weight tranny oil? - Mustang Evolution
Old 04-20-2004, 09:42 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
What fluid does the T-5 manual transmission use? The spec's page here at V6stangs says that it's mercon auto tranny fluid, but that just doesn't seem right to me.
IS that right?
The 5.6 pints seems right.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-20-2004, 10:09 AM   #2
01mineralgrey6's Avatar
thats right, mercron
-Tony
'99 cobra 'vert
Old 04-20-2004, 10:12 AM   #3
Region: Iowa
wow... that's just weird. Thanks though.
Old 04-20-2004, 10:14 AM   #4
no problem, I thought it was wierd too.
-Tony
'99 cobra 'vert
Old 04-20-2004, 01:10 PM   #5
Region: Iowa
So if I wanted to get new Transmission oil from Redline, can I use the SuperLight Shockproof manual transmission oil, since that says:
"A unique product with the viscosity of 75W90 gear oil but lower internal friction similar to that of an ATF. Used when temperatures are not high and when the maximum power output is required such as in stock car qualifying laps."
Old 04-20-2004, 03:17 PM   #6
Im not sure, it seems like they recommend using MTL and M90 for manual tranmissions though http://www.redlineoil.com/products_g...sp?subcatID=18
Just read that they don't recommend using the light ones in trannys with syncros
-Tony
'99 cobra 'vert
Old 04-20-2004, 04:57 PM   #7
Warfire80's Avatar
Send a message via MSN to Warfire80
could try royal purple as well, heard that works real well.
2007 Honda Civic EX
2003 Dodge Ram Hemi 4x4
by Lawrence Bell
Show me a man who cannot bother to do little things and I'll show you a man who cannot be trusted to do big things
Warfire80 is offline   Reply With Quote
tranny oil carlosc Pre-2005 V6 Mustang 2 03-01-2009 09:50 AM
weight? magnusmustang Mustang Wheels & Tires 12 08-07-2008 12:38 PM
Weight of Our Stangs?? TafoyaMNAA Pre-2005 V6 Mustang 24 06-06-2007 05:34 PM
Still need help with weight KFP 1979-1995 Mustang GT 0 05-12-2006 07:25 PM
99-04 Weight Reduction! fastmustangs1 The Bar 8 04-23-2005 07:00 AM
03:06 PM
