Coolant Overflow Tube - Mustang Evolution
Old 10-24-2008, 05:29 PM   #1
IMP
Question Coolant Overflow Tube
Greetings- I have a 1995 stang with a V6 and recently replaced the tubing that connects the radiator with the plastic overflow tank but I have a very small leak at the fitting on the radiator end which is allowing air to enter the system. It seems as though the sizes of the radiator and tank outlet nozzles are different. I used fuel line for the replacement tubing because it was the closest thing in size I could find and also used hose clamps. Is there special tubing for this and if so what size should I use? It doesn't make sense that two connections used on the same hose are different.
IMP is offline   Reply With Quote
Old 10-26-2008, 12:38 AM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Coolant Overflow Tube
i would try a small hose clamp first, and see if clamping it down would fix your problem
SaturnMan8227 is offline   Reply With Quote
Coolant level Foxone Pre-2005 V6 Mustang 3 10-13-2009 07:41 AM
98-04 V6 Overflow bottle tube connection DJeff68 Pre-2005 V6 Mustang 3 06-23-2009 07:29 AM
Long tube header vs. short tube USMCSS 1996-2004 Mustang GT 5 12-24-2006 05:06 PM
Coolant question bryanscle Pre-2005 V6 Mustang 12 06-09-2005 09:02 AM
10:34 AM
