Rear springs... - Mustang Evolution
Old 04-22-2004, 10:58 PM   #1
Tbird232ci's Avatar
Rear springs...
got a few questions for you guys
whats the weight difference in the rear of the 94-98 and 99+'s? are the 99+'s heavier in general?
are the springs in the *** end any different between the 94-98's and 99+'s?
basically, im looking for a stock GT spring that wont cause the *** end of my car to sag too badly, i have more weight in the rear than you guys do, so im trying to find the "best" spring for my application, the stock stang springs should lower my car about 2 inches all around if one end doesnt sag
Old 04-24-2004, 10:53 PM   #2
They should be close between the same years. Anyway as far as stiff springs are concerned normally drop springs are rated at 500 to 600 in/lb If your rear sags alot look for somthing like 600 to 700 in/lbs which would be almost a race car type setup stifness wise and would hardley move up and down.
Toxinz is offline   Reply With Quote
Old 04-25-2004, 06:03 AM   #3
Tbird232ci's Avatar
well, the problem is, i cant use drop springs, stock mustang springs will lower my car about 2 inchs, bullitt springs make the front tires almost rub
that car has just stock bullitt springs, you can see the rear is tucked just a we bit more than the fronts, im trying to avoid that
i might end up trying to find some of those heavy duty cargo springs if the rear sags that bad
Old 04-25-2004, 10:12 AM   #4
tire's Avatar
Send a message via AIM to tire
there are differences between the years but i don't know by how much. ithink the 8cyl rears would be a good idea. when i can find some on the cheap they're going on the rear of the stang, so i can't say that i've compared them.
tire is offline   Reply With Quote
Old 04-25-2004, 12:22 PM   #5
Tbird232ci's Avatar
i picked up a set on ebay for 15.50, look for auctions with no pictures, those usually go cheap
ill keep an eye out for you
Old 04-25-2004, 01:46 PM   #6
tire's Avatar
thank you. i am sure i cna find some for free or 5-10 bucks if i wait. the 6 banger rears are too soft for drag, but i sold my c springs so i had to put something in there for the mean time.
FS: '79-04 H&R Race Springs (Rear), and '05+ Corbeau Brackets/Buckles A5295 Mustang Parts for Sale and Wanted 6 03-10-2009 08:15 AM
Roush rear springs bbunt302 2005-2010 Mustang GT 9 01-03-2007 08:06 PM
rear springs lowering steeda jimmy_beaner Mustang Parts for Sale and Wanted 0 05-16-2005 06:59 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
GT rear springs Tbird232ci Mustang Parts for Sale and Wanted 1 04-23-2004 10:50 PM
10:06 PM
