ecu questions - Mustang Evolution
Old 10-26-2008, 07:15 PM   #1
ecu questions
ok i am currently experimenting with a hydrogen generator on my car its a 94 v6 mustang. For the most part it works and i can tell a big difference in the first 20 min of running it faster acceleration and it runs smother.....then, bc the o2 sensors are reading more oxygen in the system than usuall, it then dumps more fuel ....not what i want.
Is there anyway to adjust the computer to where it does not read the oxygen sensors..i have 4 or to put the computer in an open loop to where its reading factory settings with out reading imput from the senors ? And is there a way to adjust the amount of fuel sent to the motor by the injectors. Or a way to lean or richen the fuel mixture on the go.
Any and all input on this subject would be greatly appriciated
Mikemx250 is offline   Reply With Quote
Old 10-26-2008, 11:22 PM   #2
Send a message via AIM to wh!te_stang Send a message via Yahoo to wh!te_stang
Re: ecu questions
I know with an sct x3 flash tuner you can turn off the o2 sensors that should probably help fix the problem.... because then it wouldnt sense the extra oxygen and shouldnt add the extra fuel
wh!te_stang is offline   Reply With Quote
Old 10-28-2008, 04:20 PM   #3
Re: ecu questions
where could i get one of those tuners?
Old 10-29-2008, 11:29 AM   #4
1234's Avatar
Re: ecu questions
Atomic performance, american muscle, Total Performance Solutions. They are all site sponsors.
ecu chips cmanzi79 Pre-2005 V6 Mustang 2 11-04-2005 05:24 PM
ecu chiping tim11 Pre-2005 V6 Mustang 16 11-04-2005 06:52 AM
reset ecu: how? tedness Pre-2005 V6 Mustang 5 07-04-2005 11:10 PM
ecu upgrade? koloaboy_327 Pre-2005 V6 Mustang 2 02-02-2004 04:48 AM
ECU number MusclesFromBrussels Pre-2005 V6 Mustang 6 09-19-2003 04:54 AM
09:55 PM
