Upgrade list! - Mustang Evolution
Old 04-28-2004, 09:39 PM   #1
Upgrade list!
Well if my car turns out to be OKAY. Im goin to really start upgrading. Zimstang i love your mustang and i want your rims lol! Can anyone find me rims like his for cheap? Also i want to dress my engine up a little bit. SO i was thinking a cold air intake for looks and performance. Just some little easy things i can install for right now. So any suggestions?
Car setup-3.8L v6 Mustang-Auto-Dual Exhaust-Custom-Fog Lights
eNvy is offline   Reply With Quote
Old 04-28-2004, 09:57 PM   #2
NavyStanger's Avatar
Send a message via AIM to NavyStanger
The first places to start, for looks and performance, are going to be general maintenance. Give your car a full on tune-up, new plugs(use autolite platinums for long life, copper if you dont mind changing them often for a small performance improvement), wires, filters(air,fuel,oil), pcv valve, some injector cleaner, rotate your tires, a good synthetic oil/filter, etc, etc.
For appearance, get a good 3 step cleaner/wax/polish, a clay bar, and start your wax job on your car over. Well worth the time. A good base can be kept looking like a fresh coat with a wash on the weekend and a quick detail spray, only having to re-wax every 4-6 weeks. Also depends if you park outside or not. You can dress up your engine bay, or just clean it up with a steam cleaner.. try not to put a hose on it or spray a bunch of chemicals in there. Can get some interesting plug wires, from extremeffect.com, other little items to go with your CAI. Ebay CAI isnt bad for price/looks.
NavyStanger is offline   Reply With Quote
Old 04-28-2004, 10:12 PM   #3
01mineralgrey6's Avatar
He will probably be getting rid of them soon. Don't quote me on it though
Little easy things would be the CAI or an Underdrive pulley. But you should check this out http://www.mustang-forums.com/forums...ead.php?t=5654
-Tony
'99 cobra 'vert
Old 04-28-2004, 10:36 PM   #4
Zim
You want to **** me?
Zim's Avatar
ill sell you mine REAL cheap when i get my steedas
I like toys
Old 04-29-2004, 04:50 AM   #5
Danger Dude's Avatar
I would not spend extra on platinum plugs on a V6 stang. Just not worth the extra money. Get the autolight copper or the original motorcraft sparkplugs. With a well tuned Ignition system and a properly running fuel system standard plugs will last quite a long time. The fact is platinum or any high dollar plug will not magically give you better mileage or power.
Old 04-29-2004, 07:41 AM   #6
Stock Motorcraft plugs are double platinum. Platinum plugs are generally not significantly more expensive than copper, if at all. They simply last longer. Copper plugs are generally a grade cooler than platinum, and better for your engine. However, they do not last nearly as long. Autolite copper, and stock Motorcraft plugs are fine choices.
You make it sound like I was trying to tell him he'll get more power with platinum plugs.... Guess everyone needs to feel important.
Old 04-29-2004, 08:56 AM   #7
Stock Motorcraft plugs are double platinum. Platinum plugs are generally not significantly more expensive than copper, if at all. They simply last longer. Copper plugs are generally a grade cooler than platinum, and better for your engine. However, they do not last nearly as long. Autolite copper, and stock Motorcraft pugs are fine choices.
Actually I was not hammering you and I am in no need to feel important so that remark was unnecessary. I was however pointing out advertised claims by plug manufactures of increased power and mileage which would be comical if it was not such a problem with false advertisement and outright fraud in the automotive industry.
Old 04-29-2004, 09:02 AM   #8
Ponycarman's Avatar
Platinum plugs can help power and mileage, but onlyif the ignition system is weak. Platinum plugs fire easier than standard plugs, helping to crutch a weak ignition spark. This is something a stock, properly work Ford ignition does not have as a problem.
But if you had an old car with a points ignition then yeah, platinums might show an improvement.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 04-29-2004, 09:06 AM   #9
Steve
That is why I made this statement
Danger Dude: With a well tuned Ignition system and a properly running fuel system standard plugs will last quite a long time.
Old 04-29-2004, 03:46 PM   #10
Stock in Mustangs: platinum. I also never stated he'd see gains, it's just part of a tune-up, and where you should start. I also suggested some tried and true plug types in our vehicles. A lot of people gravitate towards NGK and Bosch, when they're not really the best for our application.
But yeah, truth in advertising is a far away dream in the automotive industry. Take HP at the crank for instance. You'll never see it, but they found a way to tell you your car makes more power than you'll ever feel.
ZMax is another good one. Still a dusty old box of that sitting on the shelf at the local Autozone. It sucks not being able to take manufacturer's claims at face value, in a world where generally speaking truth in advertising is taken seriously. Some of these companies get away with murder, like the intake fan makers.
Next on the list army-mustang 1996-2004 Mustang GT 11 11-30-2009 02:16 PM
To Do List 1995procharged 1996-2004 Mustang GT 1 08-31-2009 07:19 AM
Mod List GT-Eater Pictures and Videos 2 03-11-2005 09:49 PM
List Of Parts I Need For A V6 hawks05 Mustang Parts for Sale and Wanted 7 03-05-2005 10:20 PM
03:44 AM
