DPFE sensor - Mustang Evolution
Old 07-29-2003, 11:13 PM   #1
stuff breaks !!! being a divability specialest a ford dealership i have replaced alot of DPFEs it is a common problem on al makes dont condim ford for it and i dont know why you asked how it worked because u hit the nail pretty close to the head and if your pretty handy with tools u could have fixed it yourself all u needed was a 1/4 inch 5.5 deep socket and a 1/4 inch ratchet there is only 2 bolts and its prety easy to get to thats if its a 94-98 but on a 99 and up i could do it blind folded dissconect the connecter unplug to hoses replace sensor and reassemble but u couldnt clear the code unless u had a compatable scan tool at hand what code did u get a P0401 ???
MUSTANGJUNKY420 is offline   Reply With Quote
Old 07-30-2003, 02:11 AM   #2
i had mine replaced also for the same #### you said.
OldManNewHotrod
http://images.cardomain.com/installs.../266659_16.jpg
Mods Made Thusfar:
17x9" Black Bullet rims w/Khumo ASX's 275/40/17
GT Take Off Dual Exhaust w/Dynomax Turbo's
K&N Performance Intake (FIPK)
ASP UDP
Flex's Phenolic Intake Spacer
So Cal Diablo Chip
373 Gears with Tlock
crabmeat is offline   Reply With Quote
Old 08-01-2003, 07:51 PM   #3
slvr2000stang's Avatar
A lot of those are being replaced & warrantied.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-01-2003, 09:15 PM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Re: DPFE sensor
Originally Posted by 01slo232
The DPFE has two ports on it, one connected above the EGR restrictor and one below.
I thuoght the DPFE was connected to the Heades and measured how much air goes through them.
My 95 has two tubes that go to the headers, doesnt touch the EGR Vavle.
Rellik is offline   Reply With Quote
EGR/DPFE/ Problems in general. runvsofthisbull Pre-2005 V6 Mustang 0 03-16-2010 04:55 PM
O2 SENSOR redGT773 2005-2010 Mustang GT 21 01-29-2009 01:17 PM
2001 DPFE replacement oyarsa Pre-2005 V6 Mustang 5 11-07-2008 09:10 AM
M.A.F. Sensor 03GTNEWB 1996-2004 Mustang GT 5 07-15-2008 11:45 AM
2002 Mustang dpfe sensor SonikBlueStang Pre-2005 V6 Mustang 4 04-17-2006 08:45 PM
10:18 PM
