Attention: 99-00 Mustang owners Helpful info Read this. ACT! - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 07-15-2003, 12:27 PM   #1
tire's Avatar
tire is unknown around these parts
Send a message via AIM to tire
i may have residue in my upper intake. also, slight oil residue on #6 and some on #5.
'00 v6 5spd
-austin
tire is offline
Old 07-15-2003, 03:31 PM   #2
ericstanley is unknown around these parts
I've noticed that everyone that talks about this problem limits it to the 99-00 cars. Does this mean this is not a known problem with the 01+'s? I haven't checked very thoroughly, but I have noticed some oil on the top of the PCV valve, which would lead me to believe that there is oil getting past the valve... how much? I don't know. I changed the plugs before I read about this problem, so I didn't inspect 3 & 6 plugs more closely than others. What inspection I did do, however, didn't result in anything grabbing my attention as a potential problem.
Has anyone looked at the '01+'s to see if this problem carried over?
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Powerslot Rotors / Hawk Pads
Steeda Sport Springs
Steeda CC plates
Steeda HD rear sway bar
17x9 Bullets
Nitto 555s (275 rear, 245 front)
ericstanley is offline
Old 07-15-2003, 03:42 PM   #3
Horse is unknown around these parts
Send a message via AIM to Horse Send a message via Yahoo to Horse
Since the fix is to use a 2001 valve cover, I'd imagine the 2001's are all ok.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline
Old 07-15-2003, 03:50 PM   #4
i'll talk to my father-in-law who's an "engineer-of-some-sort-or-something-or-other" (his words, not mine) at Ford and find out what he knows if anything and post his findings (if, indeed he finds something).
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Steeda CC plates
17x9 Bullets
Closed Thread
Attention Ohio Cobra owners!!! 04Venom Regional Mustang Discussion 1 06-17-2009 07:17 AM
Your attention please!! Cam info..... 97Stallion The Bar 16 02-17-2005 07:22 PM
94+ owners please read Bane- Mustang Audio & Video 17 01-18-2005 08:54 PM
Attention: Mustang-Forums.com no longer belongs to me Brent The Bar 9 11-04-2004 07:14 AM
ATTENTION EVAL!!! PLEASE READ! mattstang The Bar 8 12-01-2003 05:33 PM
08:51 AM
