The do's and don'ts of Lowering - Mustang Evolution
Old 10-31-2008, 07:12 PM   #1
Renegade 800's Avatar
Region: Idaho
The do's and don’ts of Lowering.
I am looking at lowering springs. What do I need to know before I buy? I want about a 1.25 to 1.5 drop. Do I need to replace shocks? Do I need the adjustment plates?
These are cheap, are they junk?
eBay Motors: 98 99 0 01 02 03 04 FORD MUSTANG Lowering Springs V8 V6 (item 150306894489 end time Nov-01-08 18:11:22 PDT)
Renegade 800 is offline   Reply With Quote
Old 10-31-2008, 07:20 PM   #2
Re: The do's and don'ts of Lowering
I'd probably go with either eibach springs (pro-kit) or H&R's. They may cost more, but have much better quality and are backed by a warranty.
If you have a deep pocket, you could get shocks, struts, and camber plates since your already tearing that area apart. If so, I'd go with the Bullitt handling kit, it won't lower the car as much, but it includes everything for around $500.
Old 10-31-2008, 07:42 PM   #3
1234's Avatar
As sonicpony03 said either eibach or H&R's. You dont need cc plates but they are good to have. Shocks and struts its kinda up to you. But as said above if its all apart might as well replace it.
Old 10-31-2008, 07:49 PM   #4
If you get the Pro Kit C&C plates are highly recommended if you value your tired.
Old 10-31-2008, 07:51 PM   #5
My tires after no C&C plates and Eibach Pro Kit:
Old 11-01-2008, 11:43 AM   #6
WTF??? I've never seen that before.
Old 11-01-2008, 02:30 PM   #7
Don't go quite this low:
Old 11-03-2008, 01:48 PM   #8
at7311's Avatar
Send a message via AIM to at7311
^woah!
at7311 is offline   Reply With Quote
Old 11-04-2008, 08:17 AM   #9
Herbstang's Avatar
LMFAO !!!
Old 11-04-2008, 10:12 AM   #10
Aidan_04's Avatar
lol yeah.... that was a helluva trip.
Don't lower your car that much... you will trap things under it.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 11-04-2008, 10:49 AM   #11
brands
H&R
Eibach
Ford Racing
those are the main ones that are good quality. Go with a 1.5 drop ~ but once you get near or right at that level you will start to scrape things~ just part of it...
you will need CC plates, dont cheap out on these. Maximum motorsports 4 bolt plates are very good, there are others that do the job~ up to you to research and see what fits your application best.
You dont need shocks/struts when going up to a stiffer spring, the spring will out load the shocks/struts putting less wear/tear on them. The issue is the strut/shock shaft will be pushed into the housing more now that its lower~ thats were issues come from. I know the MM cc plates have shims to raise the shaft up so it is at a stock level~ or closer to it. Other CC plates may not do this.
Lowering my 04... 04SonicBlueGT 1996-2004 Mustang GT 22 10-23-2009 01:31 PM
Lowering?? Gt.Vert 1996-2004 Mustang GT 9 10-12-2009 08:12 AM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 12:04 PM
lowering? Kryptonite Mustang Audio & Video 6 10-23-2006 09:15 PM
Lowering? 19ClearCobra96 1996-2004 Mustang GT 14 05-16-2005 07:54 PM
03:49 AM
