cobra exhaust help!!!! - Mustang Evolution
Old 05-12-2004, 04:54 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
ok i got cobra exhaust for free (its a 99 car) now i kno it needs to be adapted for my car. but i dont kno how and i dont kno if it worth it. is it the part that goes over my soilded rear axle? or do i need alot? and the guy said i need a kit to make the exhaust installed to my 2003 v6? he said he could not install them on my car? but if i get gt exhaust it will only cost 60$ to install.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 05-12-2004, 09:12 PM   #2
Send a message via AIM to Black00GT
i don't think it would take much for a muffler shop to much to adapt it.
2003 Silverado Z71
Mods:
K&N filter, Black diamond plate toolbox, and billet grille on the way.
Future mods:
6" lift kit, rims and tires, Catback, Rhino lining, System
Black00GT is offline   Reply With Quote
Old 05-12-2004, 11:08 PM   #3
01mineralgrey6's Avatar
shouldn't be hard for them to bend the pipes to fit, or they can use from the muflers forward,and bend pipes for the axle and just use the tips from the cat back
-Tony
'99 cobra 'vert
Old 05-13-2004, 05:01 AM   #4
Black95GT's Avatar
Send a message via AIM to Black95GT
1999 Cobras have IRS, your car doesnt, it be easier to get a GT takeoff.
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 05-13-2004, 06:51 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Yes, but he's already got the cobra exhaust for free. I'd say use what's cheap in this case. The only real problem is the bend to clear the axles is 90* off. They may be able to cut and reweld the bend that's already there to get it pointed right.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-13-2004, 08:03 AM   #6
jimmy_beaner's Avatar
Region: Iowa
I was having some fun just laying under my v-6 last night (and yeah, HAD to put it up on ramps to do it, but it was done)... and there may be something else happening here. If you have Cobra exhaust, that's dual exhaust.... but your v-6 may not be able to be a true dual system. Does your car have one cat. or two? My car, luckily, has true dual capabilities, and it doesn't join until like where the driver's seat is. Now..... You might want to just take a look under your car. If there's only one pipe like all the way back, you'll need an adapter that basically cuts your one exhaust tube (after the cat) into two. This means your Cobra exhaust will have to be cut in half. If your car has two cats, then putting the duals on yourself is rather easy. Welding would be best, but using exhaust clamps is always an option. If it has two cats, measure how long your Cobra exhaust is, and then measure that back to your car, and make a mark on your exhaust tubing like 3-4'' shorter than that. Then, cut along that mark, and try to make it pretty like. Maybe try to get it to fit. It shouldn't be too hard of a set-up. We have the same basic car.... the exhaust my be different however. I don't know why a muffler shop would tell you it's hard... when I"m going to do all my own exhaust, and I'm not a muffler shop, and I don't have the Mustang exhaust like you do. I'm basically going to just build it, lol. If that doesn't work, my car's gonna be quite loud until I can get a kit ordered, lol.
Old 05-13-2004, 10:49 AM   #7
there all the same if there stock, and i know that the 99+has 4 cats. i'm not sure about the pre 99 tho
2003 Silverado Z71
Mods:
Future mods:
Old 05-13-2004, 12:03 PM   #8
Rick0636's Avatar
All the V6s, 94 and up that is, have 4 cats, 2 on each side, then it goes into a y and into a single exhaust, to make it dual that has to be cut off and either weld pipe from there to a set of GT duals or a fabricated or aftermarket H can go in there. Cobra duals are made to go UNDER the IRS rear axle, only way you could use it would be to cut it before the axle and run turn downs on it with no tail pipes.
Anyone else wants a set of stock Cobra catbacks I have a set of 03 Cobra 2 1/4" catbacks I will sell for cheap.
Old 05-13-2004, 12:08 PM   #9
Region: Iowa
how cheap? and I still think I'll make mine. Ummm, 2 cats on each side? would it be louder if I took off one on each side.... or is that a no no (aside from the possible legal aspect of it)?
Old 05-13-2004, 12:48 PM   #10
it will set of the check engine light....Ricks GT did with high flow cats. but if you have no emissions or inspections where your at cut them off at your will. I wouldn't really bother doing it, just my .02
-Tony
'99 cobra 'vert
Old 05-13-2004, 01:27 PM   #11
just buy a 150 dollar off road h pipe, get some MIL Eliminators and you will be set. (Unless yo have Emssion Checks in your State then disregard what i just said)
Old 05-13-2004, 02:11 PM   #12
Rick0636's Avatar
Geez, I don't know, all you could really use would be the intermediate pipe and the mufflers, the tail pipes are made to go under the IRS rear end so you can't use those at all, and the mufflers are about like stock GT mufflers pretty much. I can't remember what it cost to ship an exhaust system, but its pretty heavy. Just shipping and maybe 20 bucks extra, that is plenty.
Old 05-13-2004, 03:55 PM   #13
well thanks for the help. do u guys think i should just buy a set of gt exhaust for 150 bucks and let that be that. or should i get the guy to work with what i have. i was looking at tail pipes and they were charging 150 for a set . and do i really need a kit to install these things or do i need a new shop?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 05-13-2004, 04:12 PM   #14
what i would do is bring them to an exhaus shop,put it on but let them bend new pipes for over the axle, then use the cobra tips of the cobra system. or just run dumps.
-Tony
'99 cobra 'vert
Old 05-14-2004, 09:59 AM   #15
Send a message via Yahoo to BlkStang4Me
I have the same issue. Bought an exhaust and ended up being a Cobra exhaust. I haven't put mine on yet because of money restrictions but I have talked to a shop that will do it. They are going to cut the pipes right after the muffler, bend new pipes to go over the axle and weld the tips on for me. It's more expensive than if you had GT takeoffs. But in your situation, your only cost is putting the exhaust on. If you went the GT takeoff route, now you will have to purchase the exhaust as well as pay to have your Y-pipe modified. And if you want, you could mess with selling the Cobra exhaust but that's just a big hassle.
BlkStang4Me is offline   Reply With Quote
Old 05-14-2004, 10:10 AM   #16
Danger Dude's Avatar
Just check around locally at all the muffler shops and have them custom make a system for you. Let your fingers do the walking thru the yellow pages. And if they say they need to look at the car move on because if they dont know enough of there business to know what a dual exhaust on the most pouplar sports car in America will cost they are dumbasses and dont know their business very well.
Old 05-16-2004, 07:55 AM   #17
well thanks every one for the help. i think ill take my work some where else.
Delta Sigma Phi
www.DeltaArmsCo.com
exhaust
03/04 Cobra exhaust 99-04 GT/Cobra X-pipe slostang Mustang Parts for Sale and Wanted 0 11-05-2007 12:33 PM
KB Cobra Vs. Ford GT With Exhaust And Tune JROC Pictures and Videos 36 01-12-2007 07:05 PM
Cobra Exhaust Justin 1979-1995 Mustang GT 9 12-27-2006 11:00 AM
cobra exhaust oaktonarcher Pre-2005 V6 Mustang 5 04-08-2004 09:29 PM
10:49 PM
