tranny noises? - Mustang Evolution
Old 05-12-2004, 10:27 PM   #1
tranny noises?
My tranny seems to make some whining noises once in a while.
Also the clutch pedal seems to have some play?
What should i do?
The clutch was replaced at 130k roughly.
Let me know.
Trying to learn!
MustangNewB is offline   Reply With Quote
Old 05-12-2004, 10:42 PM   #2
Region: New Hampshire
Send a message via AIM to Smokedya95stang
maybe throw out bearing?
Does it do it when the clutch is out, and when u put the clutch in does it stop?
-Charles
Smokedya95stang is offline   Reply With Quote
Old 05-13-2004, 06:32 PM   #3
whine/tick? only at idle goes away when you push the cluch petal in? if so its a throw out bearing, if the tranny whines just driving around flush teh fluid with soem better fluid its about all you can do also put some sound deadener around teh shifter area under the bezel it will help keep it harder to hear.
to fix the clutch you will need a quadrent and firewall adjuster and just a note teh petal needs to be adjusted so that there is ONLY a quarter inch of play before the clutch starts to engage into neutral when you push it in, not flop just set the cruise and go down the road if you can push it in more than a quarter- half an inch before the rpms start to raise then set it in teh quarter - half inch range. err just hold the gas steady if you touch the cltuch in cruise it will turn the cruise off, you are just looking to see when the rpms start to climb thats when you know its starting to engage in to neutral.
Old 05-23-2004, 08:14 PM   #4
Mine does, but the clutch is still pretty good.
afrankart is offline   Reply With Quote
Old 05-23-2004, 08:46 PM   #5
Rick0636's Avatar
Clutch can still be good and throwout bearing can be bad, this happens a lot.
Old 05-23-2004, 09:00 PM   #6
Dom
Dom's Avatar
Send a message via AIM to Dom
Does it do it when your in first gear like cruising around the parking lot, if so, that's just tranny whine. I love to here mine.
Old 05-23-2004, 09:19 PM   #7
mine does in in 1-4 as far as I can tell.
Old 05-25-2004, 10:24 AM   #8
Rick0636's Avatar
I would still have the tranny lube changed as a first thing to try, hey, it might be almost dry, sort of sounds like it, sometimes they can develope leaks.
Tranny's making noises Zim 1979-1995 Mustang GT 22 04-07-2006 11:09 AM
tranny fsst93gt Regional Mustang Discussion 1 02-02-2006 03:08 PM
I never knew those Windows noises could be so cool WhiteStang99 The Bar 10 04-23-2005 06:23 AM
Steering noises? Dom Pre-2005 V6 Mustang 10 12-22-2004 11:58 PM
Help: Loud gear noises JimMoser Pre-2005 V6 Mustang 12 06-29-2004 08:36 AM
01:02 AM
