2000 v6 - Mustang Evolution
Old 05-16-2004, 01:21 PM   #1
Send a message via AIM to starboarder2004
2000 v6
I have a 2000 v6 ........ when ever i crank it up all the gauges go all the way 2 the right then go back 2 the left then they go where they are supossed 2 be ...........are they supossed to do that ???
starboarder2004 is offline   Reply With Quote
Old 05-16-2004, 06:55 PM   #2
01mineralgrey6's Avatar
Ive seen Pontiacs do that....never in a mustang?!?
-Tony
'99 cobra 'vert
Old 05-18-2004, 12:10 AM   #3
That's what the car does when the computer is reset... I dunno why it would be doing that when you start your car.
Silver 2000 3.8 w/ 5-speed Mods: C&L 73mm MAF w/K&N filter, 64mm throttle body, Diablosport chip, ASP underdrive pulley, GT takeoff exhaust, Spec stage III clutch, steeda clutch quadrant clutch cable and firewall adjuster, steeda tri-ax shifter, FRPP aluminum driveshaft and trac-loc differential, MSD plug wires, and Royal Purple lubricants all the way.
Cajunsix is offline   Reply With Quote
Old 05-18-2004, 02:36 PM   #4
I liek gramer
WhiteStang99's Avatar
yeah, its sposed to when u reset ur computer (disconnect and reconnect it). no clue why it would everytime u start it up...
check connections at battery, maybe fuses?
Old 05-18-2004, 06:18 PM   #5
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
my bros maro does that too, hes had his comp flashed, but i think it did it before that
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 05-18-2004, 07:54 PM   #6
k.................it isnt doin it any more i guess it just reset like yall said
Old 05-19-2004, 11:28 AM   #7
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
You may have a wiring problem. Something grounding out that's causing that. I had that problem but it was caused by junk in the connector for my SCT chip. I think it engauged the PATS on me. It thought I was stealing my own car and it wouldn't start.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 12-07-2005, 12:36 PM   #8
a00v6stang's Avatar
Re: 2000 v6
I actually had a problem the other day when i was shifting into third and my car just literally died on me, and the gauges stayed where they last were and the car wouldndt restart, luckily there was a median and i was able to go to that, and then the car wouldnt start at all, the connectors were all tight, so im not really sure what the hell happend, i got the battery fixed and still no problem yet. Anyone have any ideas what happend? Could it of been a short or anything, but its not doing it now.
a00v6stang is offline   Reply With Quote
Old 12-07-2005, 01:12 PM   #9
Re: 2000 v6
hmm that happends when the battery is diconnected, you may have a short or something on teh gauges, not sure where the gauges are triggered to rest themselves at.
2000 3.8 into a 95 66fstbck Pre-2005 V6 Mustang 14 02-08-2007 06:44 PM
My new 2000 V6 Ibanezplayer272 Pictures and Videos 21 02-26-2006 09:26 AM
AND we have 2000!!! Zim The Bar 23 03-29-2005 01:25 PM
$2000 Johnny D Pre-2005 V6 Mustang 9 05-15-2004 04:20 PM
2000$ Johnny D Pre-2005 V6 Mustang 1 05-13-2004 04:52 PM
03:07 PM
