First autocross with all the new mods. - Mustang Evolution
Old 05-19-2004, 07:45 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Well, Horse (That's the name of my car) was back this past weekend, raced him and it felt good. I got the 3 runs in the first heat in, then comming off the track my gauges all spiked, then dropped to 0 and the odometer read
Then the car died. After a few seconds I started it back up and it seemed ok.
I worked the track during the second heat and came back to my car for my last heat of racing. 2 more runs. I got the car in line to stage and it died again, so I figured since the gauges were freaking out it must be the computer chip I just installed. Rose, my fiancee told the timeing people what happened and they bumped be to the end of the heat. So I had about 20 min. I acctually managed to tear the computer out, reseat the chip and get back in line in less time than that. I staged, started my run, hit the timing lights to start my lap time and the car died again. So I coasted it off, and yanked the chip and left it out. It idled like **** and wasn't very fast but I got my last run in. I ended up with 3rd place, which I don't think is too bad. The guy who was in third beat me on his last run. Before that I had him beat by 11 hundredths of a second. That's awefully close with lap times that were generally running between 52 and 58 seconds.
Turns out I hadn't gotten all the stuff of the connectors before installing my chip last friday, so now I think I've gotten that all worked out.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-19-2004, 09:51 AM   #2
01mineralgrey6's Avatar
Good to hear ol Horse is back together...Aside from the elec. problem how do you like the heads, cam,etc?
-Tony
'99 cobra 'vert
Old 05-19-2004, 11:49 AM   #3
Region: Iowa
It's awesome. I keep looking down to make sure I'm in the right gear. It's like driving one gear lower than I usually do. I can acctually hill climb in 5th now. It's so cool.
Sowela autocross 3/21 tigercrazy718 Regional Mustang Discussion 2 03-11-2010 03:08 PM
Autocross Pics tedness Pictures and Videos 14 09-16-2005 10:04 AM
Davenport Autocross Horse Pre-2005 V6 Mustang 14 04-22-2005 03:29 PM
Warming up for AutoCross Ken The Bar 8 10-18-2004 12:14 AM
Autocross Season has begun! Horse General Mustang Discussion 9 04-30-2004 06:44 AM
01:13 AM
