4.2L in the future for me - Mustang Evolution
Old 05-23-2004, 08:24 PM   #1
Whats the best way to do this? Cheapest way? Would I be better off finding a block and starting from scratch? I am getting a Upper and Lower from RGR (already bought the Upper and buying the lower when he gets moved in to his new place and back online.) There wont be a problem using those right? I dont think so but just wanting to make sure.. lower is mainly what I am worried about.
For heads what should I do? Will I need new pistons.
Basically I need a list of what I am going to need and places where i can get it. Sizing up the price and where I need to start. I want to go the route Justang took just stay single port.
Old 05-23-2004, 09:25 PM   #2
Rick0636's Avatar
Just find yourself a Junked F 150 v6 and buy the whole long block. You can stay single port, its been done already, but if you go dual port it will get you more hp. If you want single port, use your present heads and intakes and everything else from the F 150. You want to get this from one with low miles and a good engine, if you do that the only thing you should need will be gasket sets. Might as well get a set of ARP head studs, you can't reuse the stock headbolts at all.
The only reason for changing the pistons, and or rods, etc would be if you plan to supercharge or turbocharge this engine, then you would need forged pistons and rods, otherwise use the stock ones and a good new set of rings and bearings.
Old 05-24-2004, 05:45 AM   #3
Danger Dude's Avatar
Hey Brent. With a 4.2 it comes with split ports. But a set of BV single port heads would be nice and they will flow much better than stock split ports. You will need a special cam from Robert to get more out of the 4.2. A big cam for a 3.8 is not so big for a 4.2. Like Rick said pistons will be fine unless you are going to get crazy with nitrous or supercharging. As far as 4.2 blocks look for something newer than 98. I know they had some problems with leaks in the 97-98 blocks.
Old 05-24-2004, 07:52 AM   #4
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
you can talk to my friend matthew, he's got a 4.2l that he built himself. he plans to turbocharge it
his aim name is White95v6
I don't own a mustang at the moment
dark is offline   Reply With Quote
future fastback fuctstar 2011-2014 Mustang GT 13 10-02-2007 03:13 PM
future 4.6 help jimmy_beaner 1996-2004 Mustang GT 22 08-22-2007 01:01 AM
Future look of my stang SVT_99_Cobra Pictures and Videos 18 10-23-2005 06:03 PM
Future of my 5.0 Black95GT 1979-1995 Mustang GT 9 02-24-2005 11:20 PM
Future plans? Tbird232ci The Bar 19 04-25-2004 10:36 PM
03:38 PM
