How do you clean your engine...... - Mustang Evolution
Old 05-26-2004, 10:38 AM   #1
What tools and cleaners do you suggest to clean your engine and how to go about doing without hurting anything under the hood....
Joseph1979 is offline   Reply With Quote
Old 05-26-2004, 02:21 PM   #2
Danger Dude's Avatar
I use Grease Lightning on everything in the egine bay except anything that is Polished aluminum. I use a mix of 50% GL and 50% water in a spray bottle Leave it on for maybe 5-10 min then rinse off. It comes in a gallon container and is 1/5 the price of Simple Green. You will not need to wipe much off Grease lightning lifts most grime unless it is caked on.
Old 05-26-2004, 03:33 PM   #3
Tbird232ci's Avatar
ive used simple green on mine many times, works well, then i used Purple Power, it can be too strong if you use it concentrated, but itll cut through just about any oily/greasy mess
Old 05-26-2004, 07:38 PM   #4
slvr2000stang's Avatar
Same as Corey here too.
That stuff works great.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-26-2004, 07:39 PM   #5
So Kirk you did find some Grease lightning and it worked for you too. Cool !!!!!!!!
Old 05-26-2004, 07:46 PM   #6
You bet.
Menards carries it up here. It took off a winters worth of grease & grime in 10 min.
2000 Vert 4R70W
Old 07-05-2004, 04:53 PM   #7
ttpancakes's Avatar
Send a message via AIM to ttpancakes
I just take it to a do it yourself car wash and just use the engine cleaner they have there not to bad and works great.
ttpancakes is offline   Reply With Quote
Old 07-05-2004, 04:55 PM   #8
Zim
You want to **** me?
Zim's Avatar
you gotta cover anything up when youre spraying the engine? Or is there anything really that cant get wet?
I like toys
Old 07-05-2004, 05:10 PM   #9
Fishers Stang's Avatar
at work we use a "special" cleaner, haha and a power washer... only on chevys and hondas we worrie about getting things wet, a mustang is ok to wash just to go puttin 100 gal of water on there and make sure your engine is cool,
Charles
Old 07-05-2004, 05:21 PM   #10
Zim
Zim's Avatar
i really need to clean my engine... i should probably be careful of all my nitrous wiring though
I like toys
Old 07-05-2004, 05:58 PM   #11
if you have a distributor i dont think you can wet that
Old 07-05-2004, 06:18 PM   #12
keep the area in red dry for the most part. if its under the hood it can get wet to a point.. ZIM, yeah aftermarket wires should be kept dry, same with your power wires for AMPS and what not..
Charles
Old 07-07-2004, 02:57 PM   #13
i clean it all by hand its not hard really it doesnt get in the cracks and all that good but i dont like putting water on the motor or what not......
Old 07-12-2004, 05:13 PM   #14
steedav6builder's Avatar
Send a message via AIM to steedav6builder
I use castrol super clean. The stuff is amazing. You have to be carful with it though cause its really strong.
steedav6builder is offline   Reply With Quote
started to clean up the engine bay (hiding wires 101) fast64 Pictures and Videos 4 01-07-2005 01:51 PM
How can I clean my engine? Ibanezplayer272 Mustang Audio & Video 6 10-24-2004 09:32 PM
Clean Your Engine megax29 Pre-2005 V6 Mustang 11 09-15-2004 06:54 PM
Clean/Dressed Up Engine Bay? Dom Pre-2005 V6 Mustang 39 02-06-2004 08:26 AM
05:16 PM
