Check engine light - Mustang Evolution
Old 05-29-2004, 03:50 PM   #1
Send a message via AIM to SVT_Rob
Check engine light
The previous owner of my car took off the main cats which caused the check engine light to go on. I was looking for a way to get rid of it without having to put the main cats back on because I love the way it sounds and I found those MIL eliminators. My friend said they may not work because you need an H or X pipe for those to work. Is it possible to have them work without an H or X pipe? Or could I get a chip to get rid of the check engine light and I could get some extra power from a chip anyways. Let me now what you think. Thanks.
http://www.mustang-forums.com/forums...ine=1093735581
SLP Loudmouth. K&N air filter. Main cats removed and pre-cats hollowed. Superchip Max MicroTuner. B&G Sport Springs 1.75" drop front and back. Eibach Wheel Spacers 25mm. Steeda Underdrive Pulleys. Steeda MIL eliminators. Side Scoops. Cobra bumper inserts.
324 rwhp - 329 rwtq
SVT_Rob is offline   Reply With Quote
Old 05-29-2004, 04:22 PM   #2
01mineralgrey6's Avatar
should work the way you have it, MIL eliminators just simulate working cats
-Tony
'99 cobra 'vert
Old 05-29-2004, 09:09 PM   #3
KrazyPony's Avatar
Well a H pipe or X is not that pricey, and yes a chip would eliminate that problem and you would see some gains from the program aswell!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 05-30-2004, 07:49 AM   #4
^Good point:yup:
-Tony
'99 cobra 'vert
Old 05-30-2004, 11:45 AM   #5
Zim
You want to **** me?
Zim's Avatar
Id recommend just going with a chip. If you go this route, throw some new gears in your rear diff like 4.30's or somethin along that line to make it way fast then just get the chip when somethin like that is done and youll score extra power, get rid of that nasty orange light, and have new gears... win win win situation
Also, do you plan on doing anything else to the car in the future? If so what?
I like toys
Old 05-31-2004, 01:41 PM   #6
In the future, I was thinking of getting the same rims but 10.5" for the back and maybe just lowering a 1" to 1.5" at the most. When I had my V6 it was at stock height and I would barely scrape the speed bumps at school depending where on the speed bump I hit. I don't what to go very low because of that. I was also thinking of getting different cams for it but that would be very expensive so I'm not to sure about doing that. Other small things I might do may be getting different underdrive pullies, maybe headers, or other types of mods like that.
324 rwhp - 329 rwtq
Old 06-01-2004, 04:10 PM   #7
nice car!
All pigs are useless!
widowvirgin is offline   Reply With Quote
check engine
Check Engine Light - Help! Eeyore General Mustang Discussion 15 04-23-2009 07:26 AM
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light donnie Pre-2005 V6 Mustang 1 05-22-2006 02:53 PM
04:20 PM
