60mm TB adapter harness - Mustang Evolution
Old 05-31-2004, 01:45 AM   #1
97Stallion's Avatar
Well I was told this work work, has anybody tried this yet? It's ford part# M-9989-A1. It retails for $14.
Living one day at a time!
Old 06-02-2004, 07:55 PM   #2
M-9989-A1 converts V6 TPS plug to 5.0 TB's!!!
1. Re-drill bolt pattern for V6 TB pattern
2. hack off MOST of the throttle arm (leaving the
return spring portion)
3. grind the remaining surface FLAT
4. weld on MOST of the 3.8 throttle arm (less the
return spring portion, just reuse the part the cable
hooks to)
5. making the crossover tube larger is a MUST and a
big job! 55mm at least... that matches the
flow rating of the 60mm TB (remember, no shaft to
block airflow)
6. Re-use your 3.8 IAC (idle bypass motor)
7. SPLICE in the 5.0 TPS to your 3.8 wiring harness.
The 3.8 TPS is "clocked" 90* off from the 5.0 TPS...
Other than that, it is a "simple bolt-on!"
60mm is also the practical limit for the 3.8 Upper,
the "choke point" can only flow about 550 CFM and the
5.0 TB is rated by FORD to flow 535-540 CFM. it is
very hard to port the choke point on a 3.8 Upper,
because it would intrude into the bolt bosses of the
upper to lower intake hold down bolts.
5.0 TPS to 3.8 wiring harness wiring schematic:
5.0 TPS colors.................goes
to..................3.8 harness
Green/Green..............................................Gray/White
Black/White..............................................Gray/Red
Orange/White.............................................Brown/White
base color/tracer (stripe) color
**** Note! Not all 5.0 TB's have the tracer color, but
it is listed
for those that do.****
When cutting the 3.8 harness wires, leave enough wire
on the plug to reinstall it in the future
if the car is ever returned to stock condition. Use
butt splices and shrink wrap to connect wires.
Gaston:
2 minor additions to RGR's info:
-There is a TPS part number for later
(towards '93) for 5spds and others for aode,
I ordered one of each and one is clocked 90*
and the other is not. I forget which is
which, they both work and cost the same so
this is useful info
-FMS sells a SN95 to "fox" TPS adapter. Its
not too expensive either, only like $10, if
you want to avoid the splicing.
This is something RGR posted on v6p a while back, it may help.
Jason Starkey
2006 Vista Blue 4.0 Mustang
www.VMPTuning.com - SCT Chips, Flashers, and Dynotuning.
Phone: 321-206-9369
Email: Jason@VMPTuning.com
JasonVMP is offline   Reply With Quote
Eclipse CD3100 + wiring harness & double din adapter jimmy_beaner Mustang Parts for Sale and Wanted 2 04-07-2008 06:56 PM
M112 Adapter sonicpony03 Pre-2005 V6 Mustang 5 12-16-2007 06:41 PM
tb adapter for a 94-95 gt davis1d0 Mustang Parts for Sale and Wanted 2 08-27-2006 02:45 AM
60mm TB from 99-04 97Stallion Mustang Parts for Sale and Wanted 12 04-01-2005 12:47 PM
60mm throttlebody on 98GreenStallion Pre-2005 V6 Mustang 23 01-13-2005 05:57 PM
11:02 AM
