Engine Starting... - Mustang Evolution
Old 05-31-2004, 02:29 PM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Engine Starting...
Is it normal for the engine to take about 2-3 seconds to turn over? Or is it a sign of my battery wearing out or anything else? Im a newbie so im just tryin to learn, thanks for anyone that has enough patience for me.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 05-31-2004, 02:41 PM   #2
Rick0636's Avatar
Check for corrosion on your battery terminals first, if there is any, clean them up good and see if that helps, if it does then that might be your only trouble. I could also be the starter solenoid gone bad. I recently had to replace that on my Ranger. It could be the battery, but you may want to check these little things first, also if you can check it, check the water in your battery to see if its low.
Old 05-31-2004, 02:43 PM   #3
Rick0636's Avatar
My Ranger is a 95, I bought it new, that battery came with it, still going strong, over 75,000 miles on it.
Old 05-31-2004, 02:48 PM   #4
Yea there is corrosion on the battery, how might I go by cleaning that up? certainly just not wiping it off, correct? And also a good thing to hear about that ranger battery, may I ask what kind it is? I got my Mustang not too long ago it has about 61,400 miles on it, but im not sure if the battery has been changed,and I did buy from the original owner, it dosent look its been changed though cause theres quite a bit of corrosion on it, its just I dont know how to clean it up and I dont want to try and guess until I get a sure way of doing it. Thanks again man.
Old 05-31-2004, 03:46 PM   #5
I liek gramer
WhiteStang99's Avatar
my fav way to clean corrosion from terminals is Coca-Cola. take some coke in a cup u wont wanna drink out of and dip the terminals (1 at a time) in there. itll say, "Fizz." then when it stops, take it out. Like new!
edit: shrink that sig... :thumbs2:
Old 05-31-2004, 04:06 PM   #6
Great, thanks for the tip, ill do it that way then. Thanks!!! Oh and I did resize it down to size, hopefully its small enough!
Old 05-31-2004, 04:25 PM   #7
Rick0636's Avatar
Sig picture needs to be about the size of mine. Or White stangs. Baking Soda and water will work as good if you have it. Also scrape the inside of them with a knife or use a small wire brush on them. Good luck! Same for the battery terminals themselves, you can also put a light coat of oil of some kind on them after you put it all back together this will slow down future corrosion. Oh, the battery in my Ranger is the factory Motorcraft one that was put in it on the assembly line.
Old 05-31-2004, 04:46 PM   #8
You can get a wirebrush battery terminal cleaner at Autozone for like two bucks. It goes over the battery terminals and inside the connectors and scrapes them off. Works great.
Laser02 is offline   Reply With Quote
Old 05-31-2004, 05:08 PM   #9
Rick0636's Avatar
Yep, those are a good tool to have around, and like Laser02 said, they aren't expensive.
Old 05-31-2004, 06:58 PM   #10
I liek gramer
yep, tools are good too. but i only use them when i have to.
my sig is a little large... might work on that sometime
starting with warm engine jorge gonzalez Pre-2005 V6 Mustang 1 08-04-2010 06:38 PM
Starting to build engine. upton7 General Mustang Discussion 2 07-21-2010 06:46 PM
starting off utmusicnut Pre-2005 V6 Mustang 12 08-28-2005 12:28 AM
Starting engine ???? StreetRacer4371 1979-1995 Mustang GT 4 01-02-2005 11:57 PM
06:35 AM
