Coil over suspension - Mustang Evolution
Old 06-03-2004, 02:55 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Two questions. What stores, online or otherwise, carry mustang coilover kits? I can find places to peice stuff together, but I don't know what I'll I need, so all in one kit would be best, probably.
Question Two, Coil overs have much softer spring rates than regular springs. What spring rate for a coil over would be comparable to, say ford C springs at 650 LB-IN..
Any ideas?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-03-2004, 04:04 PM   #2
Zim
You want to **** me?
Zim's Avatar
try www.stangsuspension.com
I like toys
Old 06-07-2004, 08:13 AM   #3
Region: Iowa
Thanks, that was exactly what I was looking for.
Old 06-07-2004, 07:27 PM   #4
Tbird232ci's Avatar
the rates are softer because the spring placement and angle changes, so there is less leverage to compress the spring, making a less firm spring seem just as firm
Old 06-08-2004, 07:29 AM   #5
Region: Iowa
I realize that, what I was asking is what the comparison is, I have ford C springs right now, and they have a 650 Lb rate. What spring rate for a coil over would get me the same stiffness. I know it will be lower, I just don't know by how much? Should I look for a 100Lb spring? 300? What?
Old 06-13-2004, 07:14 AM   #6
i don't know but you could ask the people at stangsuspension.
All pigs are useless!
widowvirgin is offline   Reply With Quote
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
Evaporator coil adumortier 1979-1995 Mustang GT 3 05-31-2008 11:24 PM
Demon Coil? corkwood06 Pre-2005 V6 Mustang 3 05-28-2008 03:37 PM
Coil Over Suspension bluemustang 1979-1995 Mustang GT 12 04-04-2007 12:14 PM
01:54 AM
