Motor Oil - Mustang Evolution
Old 06-03-2004, 10:41 PM   #1
jimmy_beaner's Avatar
Region: Iowa
Motor Oil
would you guys say Motorcraft is the best oil for a Mustang? Like over Havoline... Mobil 1.... all the others? I'm using synthetic, and right now it's Havoline, but a good friend of mine, who's in the Auto industry says ''motorcraft is made by Ford, for Ford, and it's the only thing that goes in my Ford''... But I don't know. Does Motorcraft make the best motor oil for a Mustang? It is a racing car. Mobil 1 is a racing oil.... NASCAR shouldn't be all that wrong.
Old 06-03-2004, 10:59 PM   #2
Motorcraft is just another name for raping you up the ***.
Laser02 is offline   Reply With Quote
Old 06-04-2004, 12:53 AM   #3
97Stallion's Avatar
Ford builds cars(engines), Nascar builds them better and for racing, go with what you think.
Living one day at a time!
Old 06-04-2004, 07:37 AM   #4
TruPony's Avatar
I use and will only use Castrol GTX in my cars. It provides max. protection for max. performance for all engines.
TruPony is offline   Reply With Quote
Old 06-04-2004, 08:57 AM   #5
01mineralgrey6's Avatar
I run mobil 1, but i ran the motorcraft 5w20 while i still had warranty.
-Tony
'99 cobra 'vert
Old 06-04-2004, 09:09 AM   #6
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Mobil 1 here
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 06-04-2004, 09:33 AM   #7
Rick0636's Avatar
Ford (contrary to the belief of some idiots does not make ANY motor oil) Motorcraft or otherwise, they simply take bids from different oil companies and buy from the lowest bidder. All oils must meet current specifications of SAE or they cannot be sold, they can be better, but they must at least meet these specs. SAE Society of Automotive Engineers. One oil, dino or synthetic must meet the same basic specifications, as any other. Basically its whatever brand you prefer. There is also a letter which delinieates the current or which ever SAE approval the oil has such as SAE-J or otherwise, I am not sure what the current letter is, but you should check for the current approval letter as some discount stores have been known to sell old oil.
Old 06-04-2004, 11:44 AM   #8
slvr2000stang's Avatar
:thumbs2: Thank you Rick
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-05-2004, 06:19 AM   #9
I use what is on sale in 10w-30 when I need oil change
My race car gets the same in 20W-50
Jayber is offline   Reply With Quote
Old 06-05-2004, 06:21 AM   #10
I will say I ONLY use Motorcraft filtes in my street cars and Puralator or Motorcraft Racing filters in my racer.
Old 06-05-2004, 09:20 AM   #11
Zim
You want to **** me?
Zim's Avatar
i usually use quaker state synthetic cause thats what the oil changing place has around here
I like toys
Old 06-05-2004, 12:09 PM   #12
Rick0636's Avatar
Quaker State and a few others that used PA crude oils used to get a real bad rep around here, and from all I have seen they deserved it, apparently that crude has a waxy base, and when they make motor oil with it, it coats engine parts inside your car in a black waxy residude, I have seen engines torn down with about 1/4 inch of that crud all over every thing inside them.
Old 06-05-2004, 12:17 PM   #13
Zim
Zim's Avatar
yuck!!! ok no more quaker state...
I like toys
Old 06-05-2004, 06:10 PM   #14
Even their syntetic oil?
Old 06-08-2004, 11:13 AM   #15
Rick0636's Avatar
nah, that is just their regular oil made from PA crude oil.
Old 06-08-2004, 11:47 AM   #16
Danger Dude's Avatar
This was from a past posting of mine
Here is something to think about . The saying you should not switch brands of motor oils was true at one time. Some Oil companies used wax based products in the oil to make it viscous (thicker). Not a good thing!!! So changing it around 3000 or so miles is good and wise.
The reason for changing non-synthetic oil is it breaks down do to heat and gets contaminated with acids and ash from the residue that gets by the rings during combustion. These contaminates will corrode and etch the machined surfaces in the engine and cause bearing failure and premature wear.
Synthetic oil is a bit different it does not break down. Originally developed for jet engines that produce very high temps and spin at 30,000 rpm's or better, standard oil would not do. Some of the benefits is it really does not break down so in jet engines you dont change the oil unless water gets in it. Automobiles on the other hand still have contaminates from combustion so you have change it. I will point out though, several boat and car racers I know do not change the oil, only change the filter. I dont recommend it but there are people who swear by it. I change my synthetic every 7000 miles, if you change it every 3000 miles or so you are wasting oil. But hey its your money and your right to change your oil as much as you want. There is no major difference in synthetic oil so any brand is OK to use. For me I prefer Castrol but thats just me.
Corey
Which Brand of Synthetic Motor Oil Should I Use? jasonus03 2005-2010 Mustang GT 43 10-23-2009 09:17 AM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Oil Changes on supercharged motor BIGRED3361 2005-2010 Mustang GT 17 04-09-2009 12:12 PM
which oil upton7 1996-2004 Mustang GT 11 04-08-2009 09:21 AM
synthetic vs regular motor oil Danger Dude Pre-2005 V6 Mustang 14 07-20-2003 11:43 PM
04:33 AM
