Gas Milage - Mustang Evolution
Old 06-04-2004, 05:14 PM   #1
Send a message via AIM to 98VroomVroom
Gas Milage
I dont know what it is, but for some reason my car gets very crappy gass milage. Im talking like 150 - 180 Miles to the tank. Any ideas of what might be causing this? And how much do you guys normally get? 98, V6, Auto is what I have.
Only little boys wear bowties..
Racing an import is like being in the specail Olympics..even if you win..you're still RETARDED!!
Originally Posted by EclipseGSTdude
" my useless aftermarket 10" tach is off and my clutch is going out and my vtec controller broke and my Nos floormats were ripped off and my powered by honda seatbelt covers were cutting off circulation to my shifter arm".
98VroomVroom is offline   Reply With Quote
Old 06-04-2004, 06:19 PM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
i get around 300 in town miles to the tank, around 360 highway miles to the tank
but then, my stang is completely stock
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-04-2004, 06:24 PM   #3
Rick0636's Avatar
OK, first of all, don't check your miles per tank, check your mpg, tank miles is totally inaccurate. I recently checked the mpg on a combined city-highway fillup on my GT and got around 18.5+ I was happy with that.
Old 06-19-2004, 11:48 AM   #4
I totally agree with this. The gauge on the tank is heavily electronically dampened, and not accurate.
We can make you a program for max MPG if it is really an issue...
Alberto@American MotorSport
www.americanmotorsport.com
Supercharged '00 4.2L Mustang, 5-sp
-Vortech (custom setup using 94-98 kit), 12.5psi, IMRC's, custom power pipe, 80mm Lightning MAF, 42# injectors, FMS 8.8 rear-end, 300lph returnless pump, polished '99 Cobra's, Tri-ax shifter, 160° thermostat, FMS Aluminum Driveshaft, high-flow H
313rwhp/311rwtq
americanmotorsport.com is offline   Reply With Quote
Old 06-20-2004, 01:47 PM   #5
97Stallion's Avatar
Where in South Carolina do you live? Maybe if you live close enough I can help you out replacing a few things like your fuel filter and other stuff.
Living one day at a time!
Old 06-20-2004, 02:25 PM   #6
Does the car drive good? Idle rough. Does it do anything out of the ordinary?
Old 06-20-2004, 04:22 PM   #7
Fishers Stang's Avatar
last TOG i got 18.6mpg hehe i didnt drive nice and easy that week. on a TOG i cna go norm. about 250-300miles (from the dash readout)
Charles
Old 06-25-2004, 06:10 AM   #8
Send a message via AIM to maverik
It sounds like its time for a tuneup for you buddy... 150-180 miles per tank is bad unless you have a lot of mods or you just floor it everywhere! I drive pretty aggressively and when I floor it every where I still get about 250... if I drive nice about 320, talk about a difference! Anyways, for max mpg the best speed to go is 55 mph, after that speed your mpg drastically drops off. This assumes you are either in 5th speed or overdrive 4th. If you have a 6th gear, then 65 would be best for you. Learning to drive for MPG can be a bit tedious if you really like driving, youll have to go the speed limit, not floor it to pass cars just to get a second ahead of them, accelerate slowly on onramps to the highway and onto main roads from a stop, etc... Here is what I would do if you haven't had it done recently:
Change fuel filter
Change O2 sensors
Change oil
Change oil filter
Change spark plugs (get autolites, the local store can help you)
- Also, gap them yourself! Get a gapper from the store too, its not hard at all.
Change spark plug wires
Run a three stage system fuel system cleaner through your engine
- 1st stage is throttle body cleaner, you spray it through your intake while the engine is running
- 2nd stage is a liquid that is drawn in through your vacuum lines into the upper intake and decarbonizes your intake
- 3rd stage is a fuel injector cleaner that you poor in your tank
If your injectors are bad, you might have to get them professionally cleaned.
Change your air filter
If you do all of this and you still have problems with gas mileage, do you have any smoking from your exhaust or does it feel like maybe one cylinder isn't firing? Your coil could have gone bad and a cylinder isn't getting a spark, or the Cam position sensor is out and you are in the limp driving mode so to say.
Dan
98' 3.8 AODE
Won't ever be satisfied with power, but the car looks soooo nice!
maverik is offline   Reply With Quote
Old 06-25-2004, 06:48 AM   #9
fast64's Avatar
what are your driving habits? get on it every chance you get? burn down some rubber at every stop sign & redlight?
GO BRAVES
Old 06-25-2004, 03:00 PM   #10
i manage 21-23mpg city/hwy mix with my mods normal driving getting on it just a bit of everythign. I just clean my injectors every oil change and change the fuel filter all that little stuff helps.
Old 06-25-2004, 06:53 PM   #11
97Stallion's Avatar
You can only gap copper plugs, platnium plugs are preset. If you try to regap them they could crack.
Old 06-30-2004, 04:30 PM   #12
Send a message via AIM to PhantomGT
im around 255 per tank. so thats 20.1 mpg, automattic with 3.73's
2001 V6, Way Beyond Stock...
http://www.mustangmods.com/data/2939/sig.jpg
PhantomGT is offline   Reply With Quote
Old 06-30-2004, 05:36 PM   #13
255 seems kinda low for 20mph, i do nearly 300 a tank and get 21-22~ when i do the math
Old 07-06-2004, 12:21 PM   #14
I normaly get about 21-23 mpg in the city, but that is when I nurse the throttle and my last road trip I got 27mpg! But even when I go to the track and drive aggressivly I get at least 18 mpg.
Sharpie is offline   Reply With Quote
Old 07-11-2004, 08:53 PM   #15
sarges_heroes20's Avatar
bet u guys wish u had my beater, 30 mpg no mater how i drive it (well almost no matter) its a 99zx2 it could get cold air, and ud pullies. that would give it more power (120 flywheel) and better gas milage.
sarges_heroes20 is offline   Reply With Quote
Idle Problems and Gas milage dacoday 1996-2004 Mustang GT 2 11-10-2009 07:41 AM
What is you gas milage? timpryor The Bar 38 06-13-2006 06:00 PM
improving gas milage whitev6stang03 Pre-2005 V6 Mustang 11 02-15-2006 08:04 AM
gas milage question fast64 Pre-2005 V6 Mustang 6 08-04-2004 06:16 PM
07:57 AM
