95 Intakes - Mustang Evolution
Old 06-09-2004, 01:47 PM   #1
95 Intakes
Would the upper and lower intakes from a 3.8 95 fit a 3.8 97?
njstang97 is offline   Reply With Quote
Old 06-09-2004, 01:55 PM   #2
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
yes they will fit
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 06-09-2004, 01:57 PM   #3
Danger Dude's Avatar
Yes. The only differences is the 95 upper will have 2 fewer vacuum attach points. I have a 95 upper on my 98 all I did was buy a plastic vacuum T fitting to connect my vacuum lines. If you are deleting your EGR you wount need the T fitting
The lower is the same except the thermostat housting where the upper radiator attaches to the lower intake is a different size bolts. So you will need the 95 thermostat haousing or you will have to ream out the 97 fitting to be able to use the larger bolts.
Old 06-09-2004, 06:46 PM   #4
Originally Posted by Danger Dude
Yes. The only differences is the 95 upper will have 2 fewer vacuum attach points. I have a 95 upper on my 98 all I did was buy a plastic vacuum T fitting to connect my vacuum lines. If you are deleting your EGR you wont need the T fitting
The lower is the same except the thermostat housting where the upper radiator attaches to the lower intake is a different size bolts. So you will need the 95 thermostat housing or you will have to ream out the 97 fitting to be able to use the larger bolts.
5.0 intakes bobby88 1979-1995 Mustang GT 2 02-04-2008 04:26 PM
Intakes for sale dragonlouie Mustang Parts for Sale and Wanted 0 08-22-2007 05:53 AM
P/p Intakes lowflyn Pre-2005 V6 Mustang 14 04-14-2006 10:10 AM
v6 intakes speedyhank Pre-2005 V6 Mustang 13 08-17-2004 08:02 PM
07:42 AM
