cutting springs? - Mustang Evolution
Old 11-18-2008, 11:52 PM   #1
Question cutting springs?
has anyone cut their springs? trying to be cost effective and just cut the springs instead of buying some new ones? anyone done this? pros and cons
thanks
BlackSix is offline   Reply With Quote
Old 11-19-2008, 12:27 AM   #2
Re: cutting springs?
The pro's, it is cheap to do...the cons, you have progressive springs so you will ruin them. You can't cut progressive rate springs, only linear. You have to buy new ones...
Old 11-19-2008, 10:33 AM   #3
DaDant!'s Avatar
cost= performance and durability
cutting corners = problems and cost. IMP
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 11-19-2008, 10:35 AM   #4
^^^ Not always...I cut my stock springs, however mine are linear. That $250 I saved went to a much better use.
However, the GT's and V6's have progressive springs, so they can't be cut.
Old 11-19-2008, 10:43 AM   #5
DaDant!'s Avatar
true it depends on what your trying to cut corners on... take an intake.... you spend the 50 on the make your own kit at autozone.... and the pipe keeps coming off the damn throttle body causing your engine to f* up. (my durango). buying a fuel pump and not putting the O-ring on trying to save time to get driving again.. (my truck) lol cutting corners has been bad for me... yes i know im not very mechanically inclined
im getting there.
Old 11-19-2008, 10:46 AM   #6
Originally Posted by DaDant! View Post
autozone....
See, that right there was your problem.
Old 11-19-2008, 11:01 AM   #7
DaDant!'s Avatar
lol yeah.... that and it being cheap plastic.
im getting there.
Old 11-19-2008, 11:42 AM   #8
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
dont be a cheep and cut corners. you can find springs for under $200. check out ebay
SaturnMan8227 is offline   Reply With Quote
Old 11-20-2008, 12:07 AM   #9
SerbStang's Avatar
What car do you have? If you have a new edge V6 than here you go: eBay Motors: ROUSH lowering springs for a 99-04 Mustang V6 (item 280233657227 end time Dec-02-08 04:58:58 PST)
Roush Springs for a 100 bucks....can't beat that price!
- 2001 V6 Auto -
Mods: MAC LTs, o/r H pipe, flowmaster 40s, cai,
Motive 4.10, FRPP t loc, NGK Tr55, msd8.5mm
SerbStang is offline   Reply With Quote
Old 11-20-2008, 09:07 AM   #10
cutting a little bit (correctly) is fine but cutting to much is bad. When you cut them do NOT use a torch, use a cut off wheel. Cut the top from the bottom and the rear from the top. If you cut the rear from the bottom you ruin them.
Old 11-22-2008, 02:05 PM   #11
so whats a good spring kit to get
in the 200-250 range.. less if possible lol
and how much for install usually?
Old 11-22-2008, 09:50 PM   #12
Look into Ford C springs. If you have a conv cut .5 off the rear and 1 off the front. If you have a coupe cut .75 off the rear and 1 off the front, get c/c plates, drive and enjoy until you need struts/shocks...then get Tokico Bullits.
Or just buy the bullit kit and mm c/c plates.
Old 11-23-2008, 12:19 AM   #13
GtrTech's Avatar
Here's a how to on replacing and cutting your springs. Lowering Your Stang - MustangForums.com
The war is coming to the streets of America and if you are not keeping and bearing and practicing with your arms then you will be helpless and you will be the victim of evil.
Ted Nugent
GtrTech is offline   Reply With Quote
Old 11-23-2008, 12:50 AM   #14
But, do as you see fit...
Old 11-23-2008, 01:55 PM   #15
are cc plates neccessary? i have a 03 coupe with 115000 miles... so not to sure how much longer ill have it ya know
Old 11-23-2008, 03:42 PM   #16
Depends on how much drop you want....
I'd say anything approaching 1.5 inches and you'll need c/c plates.
If you're under 1.5 and looking for something closer to 1" drop on the front you can simply elongate the stock holes and give yourself a little more adjustment in the stock camber plates. I wouldn't recommend making a very big adjustment using this method, but if it's just slightly out it will work fine.
Old 11-24-2008, 11:14 AM   #17
Herbstang's Avatar
We have our own How to's Installing Mustang Lowering Springs
Old 11-24-2008, 10:50 PM   #18
RyansQuick6's Avatar
That write-up looks EXTREMELY familiar lol
RyansQuick6 is offline   Reply With Quote
cutting stock springs sonicpony03 Pre-2005 V6 Mustang 11 06-24-2009 08:21 AM
cutting springs.. x99xstangxx Pre-2005 V6 Mustang 11 11-07-2007 08:03 AM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 01:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 05:36 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 01:59 PM
09:54 AM
