4.2 Block - Mustang Evolution
Old 06-12-2004, 12:10 AM   #1
4.2 Block
Ok so for my first ever engine tech post, can I have "Is the 4.2 block that RGR and others offer a bored out 3.8?" For $1000 please Alex
Old 06-12-2004, 12:13 AM   #2
Tbird232ci's Avatar
What is no, it is a stroked 3.8L?
the 4.2L shares the same block and same bore as a 3.8L, but uses a longer throw crank, specific pistons and rods, to pull the piston down deeper in the block on the downstroke, giving more displacement
Old 06-12-2004, 12:17 AM   #3
gotta love this forum, nice and quick, thank you much!!! BTW What kinda hp and torque gains would one get from such an engine?
Old 06-12-2004, 08:28 AM   #4
97Stallion's Avatar
You will gain very little horsepower from a stroker kit. But it will increase you torque a very good amount. If you want to gain horsepower you need to take advantage of those extra cubes you just gained by adding some Big Valved heads, a bigger TB and a good tune. When I did my 4.2, I gained approx 15 tq across the board and about 5 hp across the board. My car was heavily modded at the time. I had Stage 3 intakes, 56mm TB, BV heads(1.84/1.5), and a 216/225 cam. Your cam, heads, intakes, exhaust and TB make all the difference in the world. If you're shooting for a good all around N/A car, you'll need at least a 60mm TB, stage 3 intakes, BV heads, Big ole cam, and Dual exhaust. Get all that done and a good tune and you be close to 270bhp, with other mods you could be over 300bhp with all engine. What year is your car BTW?
Living one day at a time!
Old 06-12-2004, 08:55 AM   #5
Dont have one yet. but I will most likely be getting a 99+, thanks for the info
Old 06-12-2004, 10:10 AM   #6
97Stallion's Avatar
If you're getting a 99+, after you do all those mods, a 70mm TB will work wonders for you.
Where to get a 4.2 block Zebs5408 Pre-2005 V6 Mustang 10 02-27-2010 01:46 PM
5.0 on a 4.6 block. DaDant! 1996-2004 Mustang GT 2 02-06-2009 08:35 PM
302 Block Help ejl22boo 1979-1995 Mustang GT 2 02-01-2009 07:50 AM
4.6L Block hawks05 Mustang Parts for Sale and Wanted 1 03-30-2005 01:16 AM
91 Block the same as 94+? Brent Pre-2005 V6 Mustang 10 11-07-2003 08:13 AM
04:01 PM
